Please Note: I no longer take an active role in this thread and also do not maintain it. The important links still work, but many of the incidental ones do not as many motherboards and such are out of production.
After answering the same questions over and over and over (and over!) for the last year (probably more) on the Forums, I'm finally going to take the time to write a relatively comprehensive guide on what to do with these wonder chips that get "no respect."
All contributions are welcome, but you are required to be extrememly specific when offering information so that it doesn't lead to 10 people asking, "what about..."
I am, by no means, a "final authority" on mobile Celerons (after all, Jon187 is the one who introduced me to them), but I may very well have had my hands on more than anyone else. 😀
Intel's Northwood Mobile Celeron
Full list of Intel sSpec IDs (Note: This Guide is in reference to the 1.5Ghz and faster CPUs; the slower mobile Celerons are not based on the Northwood core.)
Picture of the Mobile Celeron processor Note the lack of a heatspreader!
These are NOT Celeron M processors!
Before Intel introduced the desktop Celeron "D" CPU (Prescott-based with SSE3), the mobile Celeron was the only 256k cache socket 478 chip with the "Celeron" name. All desktop varities were 128k cache, higher voltage and performed miserably. That is not the case with the mobile variants!
By default, these chips are designed to work on a 100MHz quad-pumped bus (400MHz) at 1.3v. Due to the wonders of the Internet and bored people worldwide, it's a no-brainer to get these working on a 133MHz FSB just by isolating a BSEL0 pin (covered below) for an instant speed boost. But even better, with the right motherboard and some extra volts, these chips perform just as well as a full-fledge Pentium 4 in most applications (especially games) that don't utilize HyperThreading (HT), often hitting 3.2 - 3.4Ghz.
My two favorite mobile Celerons
The 1.6GHz and 1.8GHz mobile Celeron CPUs are my favorites. The 1.6GHz CPU will often hit 3.2GHz at 200/800FSB and 1.65v or 2.66GHz at 166/664FSB and 1.25v while the 1.8GHz CPU will hit 3.0GHz at 166/664FSB and 1.65v or 2.4Ghz at 133/533 FSB and 1.25v. For obvious reasons, these are good numbers. 🙂 I've also come to appreciate the 2.0 and 2.4GHz mobile Celerons as they hit 3.2GHz on a 160MHz FSB and 133MHz FSB, respectively.
My experience has been that the general limitations of the CPUs are 2.4 - 2.6GHz at their rated (1.3) voltage, and 3.1 - 3.5GHz at 1.6 - 1.7v. I've never run more than 1.7v through the CPUs since this is considered pushing the upper limits of "safe" with the Northwood core, but at least one crazy person water cooled a mobile Celeron, through 1.9v at it and got over 4GHz (and, of course, killed the CPU in no time).
Steppings
The most common stepping for a mobile Celeron is "C1" followed by the more rare "D1." In theory, a newer stepping like the D1 should overclock better, but in my limited experience with D1s, that hasn't been true. If you have a choice for the same price, I'd say to go with the D1.
The big question: What motherboards support the mobiile Celeron?
Official answer: NONE
I have never seen a statement from any motherboard manufacturer indicating they support mobile Celeron (or P4) CPUs. But that said, many have the microcode for these chips in their BIOSes, and EVERY P4 board I've ever tried will recognize the CPU using the "bent pin trick" (covered below), but some boards are far better choices than others.
All boards listed in preference of manufacturer and model and have been personally tested by yours truly.
- ASUS motherboards (3-year direct warranty) -
P4S800-MX
- Recognizes CPU and defaults to 1.65v/ish (bend pin for 1.25v)
- Full AGP/PCI lock
- Memory ratios and 1MHz increment overclocking
- Should be your first choice when buying a motherboard for this chip IMHO
- A top choice for mATX and HTPC
- Note: all boards out now are Revision 2.00. Don't pay more for a Revision 1.04 as it's old stock.
P4SP-MX
- SiS 651 chipset
- Works stock at 1.6v
- 1MHz FSB increments to 166MHz
- Supports DDR400
- Onboard coaxial digital out (great for HTPC!)
P4P800 or P4P800 Deluxe
- Recognizes CPU and defaults to 1.65v (bend pin for 1.25v)
- Full range of voltage selections
- Full AGP/PCI lock
- Overclocking can be limited by memory choice and has never been fully isolated to specific brand or speed, but I've never had a problem with Corsair Value Select
P4P8X (if you can find it)
- Can be flashed with a P4P800 BIOS
- Essentially the same as a P4P800, but likely the northbridge won't overclock as far
P4S800
- Recognizes CPU and defaults to 0.9v
- Full AGP/PCI lock
- On some boards, system will fail to POST on soft reboot...have not figured out why
P4P800-VM
- Full AGP/PCI lock
- BSEL0 mod a must with this board so chip defaults to 133MHz and 1:1 memory ratio is an option for maximum overclocking (otherwise you're at a 4:5 ratio)
- Need to use ClockGen for overclocking
- If you need dual channel and mATX, this is your best choice
- If it was easier to overclock, it would be my #1 choice
P4S800D
- The only motherboard I have ever used that detects a mobile Celeron at 1.2v without bending the pin
- Only allows for a .5v voltage increase in the BIOS
P4G533-LA REV1.02 (Comes froms a HP Pavilion 533W starting with MX serial #)
- Recognizes CPU as a Intel Pentium 4 1.8GHz (works without bent pin)
- Defaults to an unknown voltage
- Tested with BIOS v3.10
- No overclocking options what so ever that I know of.
- Intel 845GL Northbridge
- ICH4 Southbridge
- MSI motherboards (3-year direct warranty) -
655 MAX-FISR (HT Ready), MS-6730
- Recognizes CPU and defaults to 1.58v (bend pin for 1.16v, but no adjustments available if you do so)
- Full BIOS FSB/memory ratio/voltage adjustments (1.6v - 1.85v)
- Any version of this (655 MAX) motherboard is fine, FISR has the most options
- Chipset limitation seems to be in the 150 - 160 FSB range
- My #1 choice for full-size ATX HTPC (in other words, it's what I use)
661FM-L, MS-6540G
- Pin needs to be bent
- Only FSB options are 100/133/200, so 133 is likely all you'll get due to the voltage
- Nice features and stable
- New versions of this board are available, but I haven't tested them...please report if you have!
- Gigabyte motherboards -
GA-8S661FXM
- BSEL0 pin needs to be bent
- Defaults to 1.2v, though I have one board that does 1.25v
- Full AGP/PCI locks
- 1MHz increment overclocking and memory ratios
- Very stable
GA-8S648FX-L
- Defaults to 1.2v
- Mild voltage adjustments in percentages up to 10% (1.37v)
- ECS Boards: -
661FX-M v1.0
- Defaults to 1.6v
- Onboard Serial ATA (964 SouthBridge)
- FSB adjustable in 1MHz increments, but wacky BIOS restricts it to 132MHz FSB unless you break the 133MHz pin, which would then restrict you to 166MHz
- Running memory at anything other than 1:1 causes system lockups
- AGP/PCI locks don't seem stable
PT800CE-A REV1.0A (HT Ready)
- Recognizes CPU as Mobile Intel Celeron 1.80Ghz
- Defaults to 1.55v (bend pin for 1.20v)
- Tested with BIOS v1.1A and v1.1E
- VIA VT8753 Northbridge
- VIA VT8233 Southbridge
- 1Mhz increments in the BIOS and onboard jumpers to switch in between 100-133-200MHz bus
- Can boost voltage up to 6% higher
P4VXMD REV1.0
- Recognizes CPU as Intel Celeron 1.8AGhz
- Defaults to 1.60v (bend pin for 1.20v)
- Tested with BIOS v1.2D
- VIA PT800CE Northbridge
- VIA VT8237 Southbridge
- Can switch bus speed in the BIOS in jumps
- Jetway Boards -
650DF
- No pin mods required
- SIS 651 chipset
- Onboard video, 5.1 sound and optical out
- FSB adjustments and memory ratios but no PCI locks
- Great candidate for tiny HTPC
Barebone Systems
ASUS Vintage barebones SIS 661FX system
- P4S800-MX motherboard version 2.01
- AMI instead of AWARD BIOS
- Needs pin bent
- Limited overclocking options / 133 FSB all to expect
I'm not sure why ASUS put a different BIOS on these. It should be possible to hot flash the BIOS to AWARD, but I haven't tried it.
eCube EG65
- Requires bent pin to POST, defaults to 1.2v
- No voltage adjustments
- No FSB adjustments
- Limited HSF selections due to non-removable drive cage
- Dual side windows
- Great candidate for 133FSB pin mod and stylish HTPC
Shuttle XPC Model SB65G2
- Defaults to 1.62v/ish
- 1 MHz increment overclocking and memory ratios
- Full range of voltage selections!
- Dual channel memory
- Fan speed controlled by BIOS/temperature
- Depending on the I.C.E. heat sink, may need to use the "penny trick" or just use a low-profile HSF (like a Zalman CNPS5700 without the shroud)
- 220 watt PSU makes it hard to recommend anything more powerful than a 9600XT
- Integrated 802.11b is dated, but fine for web surfing
This rig was recommended to me by BigBadBiologist, and what a pleasant surprise it is! It's full of features in the BIOS and has crazy-high voltage selections, allowing for better overclocks. A mobile Celeron in this machien makes a superb HTPC or LAN gaming box on the cheap and cool!
Shuttle XPC Model SB61G2V3
- Full range of voltage options
- 250-watt PSU gets you into 9800 Pro territory
Heatsinks
Since the mobile Celeron does not have an integrated heat spreader, you need to be SURE the heat sink you choose is making contact with the core BEFORE applying power, or there's a good chance you'll have a dead CPU in a nanosecond. 😉 IMHO, the best way to verify a heatsink will work for you is to install it, then remove it and verify that the excess thermal grease was pushed aside from the pressure of the heatsink being installed. If you have any doubt, use a different heat sink.
Remember that you don't necessarily need anything fancy if you're going to be running at the lower voltages. At 1.2/1.3v and even 2.65GHz, there's no need for fan noise. 😉
Heatsinks that I have tested and verified to work:
Thermalright SLK 900/947/948U
Zalman CNPS7000/A/B AlCU/CU
Zalman CNPS5700D-Cu (with and without shroud)
Spire CopperStream II (my personal favorite)
Spire Easystream
Any Intel socket 478 retail HSF
Heatsinks I have tested and verified need the "penny" or Zap's "floppy trick":
Vantec CCK 7025
Zalman/PCToys CNPS6500 (I'm hoping to get around to seeing how this works passively with a CPU at 1.2v)
CPUMate D132HM4
Power supply (PSU) requirements
So how much juice do you need to power your new 3GHz+ system? Not much...in fact, a fully loaded 3.2GHz 200FSB system with two opticals, a hard drive and Radeon 9600 non-Pro 256 meg will run just fine on a 240-watt PSU (consuming around 150-watts under load)...and do it silently. I do recommend that you use a PSU of reasonable quality, though.
Enough already, how do I mod this chip?
There are three basic mods that can be done to mobile Celerons.
1) The "bent pin" trick. By bending or breaking pin AE1 (indicated in WHITE), motherboards that don't recognize a mobile Celeron should POST and default the CPU's voltage to 1.2-1.25v. I've never seen it default to its rated voltage of 1.3v. If you are careful, you should be able to pen the pin and put it back 2-3 times before it breaks off completely.
2) The 133FSB trick. Pin AD6 (highlighted in red) controls the 100/133 FSB option. Your two choices here are to break the pin off, or try isolating it with nail polish. My advice would be to test and verify the CPU works at 133FSB (which shouldn't be an issue on anything under 2GHz), then break the pin off -- there's no warranty to worry about! The pin highlighted in light blue is the 200FSB pin. I don't recommend messing with this pin unless you're absolutely certain your CPU does 200FSB (likely on a 1.5GHz CPU, very possible on a 1.6GHz CPU, but probably not going to happen above that without extreme voltage).
3) Wire wrapping (or conductive thermal grease, etc.) voltage trick. If you run into a motherboard that will POST the mobile Celeron processor without using the bent pin trick, but for some reason defaults to 1.2v and doesn't have any voltage adjustments in the BIOS, you CAN use this trick. Personally, I'd just get another motherboard...but here you go:
The pins colored green, plus one in white (AE1/VID4) are, from left to right VID4, VID3, VID2, VID1, VID0
The default for 1.2v is:
VID4=0 VID3=1 VID2=0 VID1=1 VID0=1
Simply connect VID3 and VID2 to get a changed value of 1.6v, or
VID4=0 VID3=0 VID2=0 VID1=1 VID0=1
If you then connect VID1 and VID2, you now get 1.70v; connect all the VIDs and get 1.75v.
Here's what the CPU would look like with VIDs 4, 3, 2 and 1 connected with conductive ink.
Refer to the Mobile Intel Pentium 4 Datasheet for technical information.
Now, you may have noticed that the bent pin and the voltage wrap tricks share pin AE1 (VID4). I have no idea if you can use both "tricks" together or not as I have never tried it. Edit: It has been reported to me that if you bend the pin, you can NOT also mod the voltage.
More to come...
Credit to and some information lifted from:
rogue1979 for working with me on the wire wrapping formula;
VR-Zone's Northwood volt mod guide Note that the voltage chart is for DESKTOP chips;
Zap's FSB pin mod page;
Steppings
P4S800-MX
- Full AGP/PCI lock
P4SP-MX
- SiS 651 chipset
- Supports DDR400
- Full AGP/PCI lock
P4S800
- Full AGP/PCI lock
P4P800-VM
- Full AGP/PCI lock
P4S800D
- ICH4 Southbridge
661FM-L, MS-6540G
GA-8S661FXM
- Very stable
GA-8S648FX-L
- Defaults to 1.2v
- ECS Boards: -
661FX-M v1.0
- Defaults to 1.6v
P4VXMD REV1.0
- Jetway Boards -
650DF
- SIS 651 chipset
Barebone Systems
- Needs pin bent
eCube EG65
- Dual side windows
Heatsinks
Spire Easystream
Vantec CCK 7025
CPUMate D132HM4
More to come...
