Howdy All!
I have a Hercules Fortissmo II sound Card. I have my XP setup with me as Admin, family members (5, 6th is too young still!
) as Users. My Sound Control App (called Gamesurround) resides in my app bar lower rt. I often switch between Speakers/Headphones depending on the Game, etc..I'm using. This App also sits in the Control Panel of course.
Problem is none of the Users have any control over this app. It does not load for them, and does not respond when they try to start it in the Control Panel. I question Hercules about it and this is their responce:
Ok, I understand that having done the same thing for some of my Games, problem is I can find nothing that looks like the Control Panel in the Windows Folder. (I do have Explorer setup to see all file types)
Anyone know where I can find the Control Panel so I can open up Permissions on the Sound App. (found nothing in the Sound Program folder that deals with this app.)
Thank You for any help!
Dear Customer, The Control Panel needs full read&write privileges in the \Windows folder. Regards, Philippe Delisle Hercules Technical Support Specialist
