- Aug 16, 2002
- 680
- 0
- 0
My configuration:
Main PC - > Cabling - > Hub < - Cabling < - Secondary PC
Running the network wizard on both computers didn't network them properly. However, if I manually set the IP settings like so:
Main:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.169
DNS Server: 192.168.0.169
Secondary:
IP: 192.168.0.169
DNS Server 192.168.0.1
I've got TCP/IP protocol installed with support for netBIOS over TCP/IP enabled, as well as installing NetBIOS protocol itself to see if that would fix it. Both setups are the same on both computers.
Both computers can see each other through My Network Places, and can usually access each other. Every once in a while, however, I get an error saying I don't have privs to view the other computer (I'm logged on with full admin privs on both stations). Also, when I enable Internet Connection Sharing on my dialup connection, the whole network goes down and neither computer can see each other, or sometimes even see themselves.
I'm sure I've probably got some sort of setting in my TCP/IP manual settings, as I don't particularly know exactly how the Default Gateway and DNS Server operate nor what I should set them to.
Any suggestions would be great. Thanks in advance.
Main:
IP: 192.168.0.1
Secondary:
IP: 192.168.0.169
