Originally posted by: RossMAN
Is the difference really THAT noticeable with RainX compared to no Rainx?
How do you apply it to the windshield? I want the easiest solution possible.
No not in my opinion. I have found that rainx actually prematurly makes my wipers go bad; thers residue and gunk that build up on the blades from teh rainx that make the wipers not works well when you do need to use them.
Best thing I have found is to have a pit free glass, and make sure it is clean clean clean. 'Barkeepers friend' is a great thing to clean your windshield, a very mild non abrasive cleaner. Original BonAmi cleaning power (the one in a gold can) works great as well. Cleanliness I have found repels more rain than anything else depending on what speed youre going and what kinds rain it is.
If you are getting streaks, your wipers are either dirty, worn out, or not making proper contact witht eh windshield. In sever cases, a really pitted or sandblasted windshield will be blurry/streaky no matter how clean it is or what wipers you use.
