Imaginer
Also, another counter to my point of spaced out large tiles of the Start screen, these can be set to be as small as desktop icons (Smaller setting in PC Settings under Display) and to size the tiles of desktop shortcuts to be the smallest tile.
This sets up a nice grid of grouped tiles with the heading above each group. This also makes the Start screen more appropriate as a launcher, as any Start menu before it.
This also is more suited for those that aren't relying on a written language organization hierarchy, but in addition, visual icons, location, and colors. In short, it can give flexibility as shown before with desktop shortcuts since XP, 98, and 95 days. But somewhere along that way, we all (myself for awhile) got accustomed to the text listing of the start menu.
But since Windows 7, I rarely use the scrolling listing of "All Programs", most of the stuff is pinned to the taskbar or immediate front of the Start menu, above the frequently used programs listings. If the Start Screen had the option to put a group that showed 8 to 18 tiles of frequently used programs, it would be JUST AS THE SAME functionally as the Start menu, but with more real estate as a launcher.
And with it interrupting the display, your eyes are diverted to selecting the program to run, text to see when entering a search, etc (Start Menu or Screen otherwise). Since you only have one pointer, you can't really multi task with another window while interfacing with the Start menu anyways, also another point why one should complain about this aspect.
The quickness of switching, seems fluid for me, not jarring. If you want jarring, I can show other areas of such (namely direct X games and flickering of resolution matching and scaling). Those games also hijack full screen operations too, hence new games offer windowed modes.
Cascading windows, seems something of the past. If there is any immediate information of programs, you can guarantee I will arrange the window sizes that will display the full contents of each program, side by side. Modern apps do this without the need to size windows or layouts of each program (and yes you can call this "dumbing down" as in "automatically interface adjusting").
If the apps can be had in their own window, it is a mix of offering multiple apps to be run like normal in Windows. The problem is, is the inherent programming paradigms of the Modern side coming from Windows Phone (apps not really treated like their desktop counterparts in permissions, and physical copies). And who is to blame for this? It is a market response into Android and Apple, and to provide a immediate solution or to fall even further behind. It is a lose lose battle.
However, as much as I mostly agree with the Start Screen and Modern areas (more so on my Surface Pro 2), I would agree in providing an option for the Start menu in full. But I would also like to point out the age of some other power options and windows for devices and settings (see my long post before in this thread). This is another crux, and just the same if Linux tries to have a Surface Pro 2 competitor (for those vouching for a "free" solution but not really in terms of immediate moderate function and support (OS and finding replacement software - virtualization and emulation isn't fully ideal, nor dual booting).
