winchester steppings
spinejam
3,503
My A64 3000+ Steppings:
ADA3000DIK4BI
CBBHD 0447TPFW
1158819L40840
Clocks to 2430MHZ w/o a hiccup on Chaintech VNF4 Ultra MB
270HTT x 9
166mem divider
1.425 VCore
23 degrees idle -- 35 degrees load
PClark99
3,834
74
ADA3200DIKBI
CBBID 0451BPEW
1173667A50427
This is the chip in my sig. Runs nice at 250x10 at 1.5V core. Not all Week 51s suck.
ADA3000DIKBI
CBBFD 04335PMW
1063547H40071
This is in my wife's computer. It runs 250x90 at 1.45V no problem.
I had and sold a Newcastle 3500 that did 250x10 at 1.5V also.
Call me lucky, call me good, just don't call me late for dinner!
pnosker
90
A64 3000+ 939
A8N-SLI
4x HT
280 FSB
9X Multiplier(duh!)
266:400 ratio for Ram
PDP Patriot PC3200 2-3-2-5 T2 (2x 512, 2x 256, dual channel)
Total speed:
2.53 ghz
screenie
Stable for 5 hours of Americas Army at maxed out graphics
oh, and running at 1.525 volts on the stock HSF
Stepping (someone tell me what this means please via PM):
1F / 0 (108) as reported by SiSoft Sandra
Edit: Forgot to mention Stock HSF + link was screwed up + random tidbits
Jman13
811
Week 51, 2304MHz (9x256) 5:6 mem divider, 1.425V, 43C load, system below.
Might go a little faster, but it was unstable at 2.4GHz, 1.5V, 100MHz mem lock, so I just said screw it, especially since my 133 divider doesn't work at high FSB (above 245 it craps out). If I was willing to push 1.6V through my chip I might be able to get a bit above 2.4GHz.
John
Moderator Emeritus<br>Elite Member
DFI NF4 Ultra-D w/ 201 BIOS
1GB (2x512) DDR400 el cheapo Micron G
OCZ Powerstream 520
XP-90 w/ Vantec Stealth 20dB 28cfm
3200+ Winnie
ADA3200DIK4BI
CBBHD 0450APFW
1169457L40464
2.6GHz @ 1.5v 260FSB/HTT 4x
55C Under full Prime95 large FFT test and passes for 12+ hrs
Passes 32M SuperPi & Memtest86+ 1.51
akugami
6,210
2,552
Forgot what week it was but 044x (so week forty something). I haven't tried pushing it much higher as I got instability at 1.5v pushing it at a higher fsb and heat was starting to become an issue. Maybe if I got a better cooler I could try pushing the voltage higher and see how far I can go but an overclock of thirty something percent is awesome.
A64 Winchester 3000+, 1GB of RAM, A8N-SLI Deluxe 1003 final bios
A64 3000+ 1.8ghz clocked to 2.5ghz w/ stock hsf 278x9 @ 1.5v
HTTx3 (Woulda tried to see if it's stable at x4 but I read there's not a lot of diff between 800mhz and 1000mhz HTT.)
512x2 Value RAM 2-3-3-8 1T (forgot but think it was 179mhz, I'm not at home right now) using 266 divider @ 2.7v
spinejam
3,503
ADA3000DIK4BI
CBBHD 0447TPFW
1158819L40840
Clocks to 2520mhz w/o a hiccup on Chaintech VNF4 Ultra MB
280HTT x 9
166mem divider
1.45 VCore
25 degrees idle -- 35 degrees load
