Winchester 3200+ at 2.6GHz
Originally posted by: vmaddogv
Well it turns out it wasnt quite as stable as i though. Played World Of Warcraft at 2.6 and it crashed, put it back to 2.5 and has been running fine all day. Maybe more voltage? I have the MSI neo2 plat (bios 1.3) does the 10% option work? Was running fine under superPi and prime95, wonder why game crashed. Currently ram is at 2.7 volts, whats the maz OCZ plat rev.2 can go to? Still gonna try for the 2.6 seems like just a little tweeking can make it more stable. Was thinking close to 60 on water was kinda high but i guess not.
How long did you let prime run???
Remember superpi is not much of a stress test unless you run 32mb and that should only last 30 minutes or so..not much of a stress as well...
Probably for serious gamers looping 3dmark for hours is better followed by 10 pass memtest and 6- 12 hours of prime
The agp is at stock voltage. I didnt let prime run too long, about an hour. I'll try to up the agp 1 mhz and see if that corrects the problem.
Zobarstyl: Your temps dont change? Although i think you are running on a custom water cooled system; mine is just using koolance exos. My block is about 36/46 idle/load and the processor 33/57 idle/load.
Since i know it can boot and run prime for some time at 2.6 i dont see why i shouldnt be able to get it stable at that speed. I would be more than happy at 2.5-2.55 so either way its good. Just glad that i was able to oc to more than what somepeople are getting.
My memory is still running at a ratio, so i think i will work on getting that 1:1 then try to get it from 2.5 to 2.6. Seems like ocz states my ram can run up to 2.9 volts and still be completly stable and safe.
With exams this week it may be hard for me to get posts up in quick responses, but ill let ya know what happens.
What weeks were those that people cannot get over 2.3 or 2.4. From the anandtech review they had a week 43, and mine is 44 possible people had earlier week processors?
