I have had this computer working for about 1year with no problems until recently. It started when I loaded "Cubasis" an audio editing program. I loaded it and it ran fine, even finished the audio project I was working on. But after editing my audio with the program, I started to burn a CD of it, that is when everything started messing up. The program that I have used for the past year for burning CD's (with no problems) suddenly now locks the computer. Even Clt, Alt, Del will not work. So now I decide to remove the "Cubasis" program, since that is when the problem started. I remove it and try the CD burner and same thing, LOCK-UP!! So I remove the CD burning software and reload it and now the CD burner works again.
I really don't need the "Cubasis" program so I just leave it out, and since the CD burner is reloaded and working again, I think everything is back to normal. WRONG!!!! Ever since this happened (about a month ago) I have noticed lots of little "bugs". Some are minor, some not.
1. When restarting the computer, it will load to the desktop, then turn blue for about 20 seconds, then go back to the desktop.
2. Win2K locks up MUCH more often than before I loaded that software.
3. Windows media player will play a video from the hard drive fine, but if it tries to download one from the internet, it locks up - every time. I have reinstalled it, but it still does the same thing. It worked fine before.
4. The last problem I have noticed is something new. This just started yesterday, so it might not have anything to do with the other things. The monitor is set to shut off after 10 min. When it does, the computer locks. Nothing works Clt, Alt, Del -- Esc -- mouse -- nothing. I have to power it down and restart. It does this every time -- very annoying. :|
Now the question: How can I get this computer totally back to "normal" -- like it was before I loaded that software??? Is there anyway to do it without starting over and reinstalling Windows?? How can I completely reverse everything that the "Cubasis" program did??? 😕
Thanks!!!
Thanks!!!
