Win11 users, you might want to check your system restore settings
AdamK47
3,246
I have a very old version which is probably useless by now. I looked at them just now and it seems to be a saas product now??? $50 a year is steep for something that may be used once or twice a year.
Acronis Home is standalone. It's a regular installation. It does come with bloat like real-time protection. I turn all that stuff off.
A///
4,351
3,158
The SaaS is what comes up when I look up the home version. Could you please link it? I wouldn't be surprised if their robots text is blocking search engines from crawling it to route more sales through their saas.
Steltek
3,222
991
In addition to turning off restore points by default, Microsoft has also disabled registry backups in Win10/11. Found that little surprise yesterday while trying while trying to fix a machine for a relative that had a corrupted registry.
mikeymikec
18,593
11,276
When you say 'registry backups', what do you mean?
I don't often check system restore outside of a new clean install scenario, but I haven't noticed SR being off by default like as a general rule.
13,588
I remember XP registry had the different hive files with BAK extension, like system.bak
Helped me to boot unbootable Windows installations few times by just booting with a rescue CD, renaming system to something else and renaming system.bak to system.
Steltek
3,222
991
This.
In versions of Windows prior to like Win10 version 18xx, there was an automatic backup of the Windows registry stored in the event you needed it to fix the machine (you could actually use regedit to control the number of backup copies it kept). For some reason only known to the space cadets at Microsoft, they disabled the backup mechanism for this. Turns out you can mostly re-enable it, but it requires several steps editing the registry and you also have to create a Windows task scheduler task to actually trigger the backups now (where it used to be automatic).
Pain in the rear orifice if you actually need it like I did on that system the other day. The relative ran the CCleaner registry cleaner on it and (of course) it totally nuked the registry. Even a repair install didn't fix it -- had to do a new clean install since there wasn't a registry backup to restore. Suffice to say, CCleaner wasn't reinstalled (and I told him not to bring it back to me again if he installed it and nuked it again in the future).
Regarding Windows system restore, new Windows installs now by default do not automatically create restore points as it is disabled. If you have an older upgraded Windows installation and system restore was activated on it, that continued to carry forward to each new upgrade.
However, if you do a totally clean Windows install on a machine, SR will be turned off by default. I suspect they did this originally due to the limited capacity of then expensive past SSD boot drives. However, that isn't an issue with the cheap larger capacity SSD/nvme drives now - you just have to remember to re-enable it manually.
