win 2k won't power off monitor
Wiglaf3
51
I have an Epox 8k7a+ mobo, and I running w2k.
In control panel under display I set monitor to power off in 15 min (or 5 or 10) but it won't turn off. This method works fine using 98se on another PC.
How can I get the monitor to power off in w2k?
stamm
Banned
Sep 15, 2001
85
i belive 2k has something called "hibernate" wich only allows the whole thing to go into stand by
not just the moniter
Wiglaf3
51
ahm, under display then "screen saver" then "power" I can set the monitor to turn off after a certain amount of time.
Does anyone else see this? If so, does it work for you?
Abzstrak
2,450
U know, I haven't bothered looking into it yet, but it doesn't work on my gigabyte 7dx either....
