imported_gear
I have an Athlon 3800X2 and ECS nforce4-A939 motherboard.
The CPU was overclocked to 2.4GHZ. I couldn't find the PCI lock on the bios.
After about one week, the ethernet didn't want to work anywore.
The litter yellow and green light still flashed. There was still response in windows when I plugged the cable in and out. But there was no connection with the cable modem.
Then I just reinstall the windows, the installation just stalled at " installing devices" step.
Disabling network at bios solved the problem.
Also tried two versions of linux, didn't detect network at all.
So I'm quite sure the network is dead.
Now I got a new same motherboard.
It's such a waste to not to overclock the CPU.
But I need the network. Is the overclock going to damage the ethernet for sure?
I guess I can always buy a usb ethernet adapater.
Thanks!
Thanks!
