Will it work?
Zizzlez
12
So I am wanting to get a 144hz monitor. But when I look on websites about the motherboards Asrock Motherboard comparison. Why would i get a 144hz monitor then, it doesnt even support it. When i looked up at the max Z97 models it didnt even say anything about how much it supports. The 144hz is a 1920x 1080. So, officially, does it only support 60hz and why do ppl get 144hz monitors then? Should i still be getting the 144hz monitor and there are ways to go around it or something? Plz info.
OlyAR15
982
242
The 144Hz monitors are for gaming, so why would you want to use onboard graphics for gaming? Get a decent video card, or don't bother getting a gaming monitor.
Zizzlez
12
I am get the r9 290. So as long as i have that I can have as good as monitor i want as long as my gpu can support it? So the ports on the motherboard can go to 144hz no prob?
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
If you're using a discrete GPU, you aren't using the graphic ports on the MB.
Puffnstuff
16,187
4,871
Like everyone has already said if you are using a dedicated gpu then you are plugging directly into it and not the mb ports which are for the onboard graphics only.
