Will I notice a 300MHz increase?
Cook1
6,315
Hey guys, running my Opty 165 at 2.52GHz @ 1.3v on water, which means I never get above 33/34C. Question being would I notice a 300MHz increase in gaming and such. I ask because I'll most likely have this chip for awhile to come, I don't want to be too hard on it.
Thoughts?
peleejosh
1,521
It may give you a few frames per second more, but not very noticeable. What voltage do you have to give it to get the extra 300?
Cook1
6,315
1.47-1.5 And temps are about 10c higher on load. Which still isn't bad I suppose.
peleejosh
1,521
Personally, I would stick with your current overclock. 300 mhz is not worth a .17 or .2 increase in votlage to me. Some may say that its on water and 1.5 is perfectly safe, but my opty runs 2.52 with 1.35 volts and it takes about the same increase voltage that your does to go up to 2.7. I run mine at 2.52 also.
Cook1
6,315
That's what I was thinking as well, guess it would just be fun to see the 2.8'er on the screen at times ;)
Avalon
7,571
178
How much voltage does it take you to do 200mhz more?
Either way, you won't notice it in games.
lyssword
5,630
25
dude just stick with current setup, easier on ur memory, less things to go wrong. You will not notice much improvement for sure.. Trust me, better b safe than sorry. Even tho its my vid card I fried with o/c i had to wait 3 weeks to rma :p So b safe folks u don't want to wait weeks/w ever for rma.. (that is if u actually can get rma for ur opty, since its designed for server not gaming as amd would classify it)
lopri
13,310
687
300MHz increase in K8 architecture is definitely noticeable.
Ronnie
1,268
My thoughts are just the opposite of most here, I would at the very least run it at 1.4V and maybe this will give you 2650-2700.
Whats the point in spending all that money on a water setup if your not going to push your chip a little.
DrMrLordX
22,701
12,652
Not in games, not typically. It'll make a bigger impact on CPU-intensive tasks like encoding, compiling, etc.
snor
889
i noticed about an average of 20 frames increase in COD2 going from 2.35 to 2.7 ghz. This is from an AMD 64 3000+ with a x850 xt card. I figured the difference would be minimal also but certain games stress the CPU more than others. If you tested it in some artificial benches, the difference would be minimal (3d mark).
