Will HD 5770 run on 400w power supply?
Wayfaerer1
15
I wanted to double check that this video card would have enough power from my current 400W power supply.
My PC:
Intel Core 2 Quad Q8200 2330 GHz
Nvidia GeForce GT120
640 GB Hard Drive
400 Watt Power Supply
20" Monitor
On the advice given by other members here, I went ahead and purchased the Radeon HD 5770 http://www.newegg.com/Product/Produc...-476-_-Product
I believe the card requires a 450W power supply? Is this correct?
Will my 400W power supply be enough? Or do I need to upgrade?
Thanks.
Jhatfie
749
I guess the real question is...what 400w power supply do you have currently? The quality of it may determine how well your system will run with a 5770 installed. A decent quality 400w PSU should have no problem running your system with a 5770. I was using a Antec Earthwatts 380w with a 5770 and a Athlon II X3 for a while in a gaming HTPC and had no issues. But if the 400w you have is some generic cheap PSU that came with a case, then you may have some issues.
CurseTheSky
5,401
Even a crap 400w power supply will run a 5770.
Maybe, maybe not. Some crap 400W power supplies are only capable of putting out 200-250W or so. I'm talking about bargain bin units like Powmax, Coolmax, Diablotek, Apevia (Aspire), etc.
As long as you have a PSU from a decently well known brand (Corsair, Antec, Seasonic, PC Power & Cooling, OCZ, BFG, Sparkle, FPS Group, Enermax, XFX, Xigmatek, Silverstone, etc.) you should be ok. There are a few bad apples in the bunch, of course, but if you give us the make / model of your PSU, we can tell you whether or not it's decent.
Lonyo
21,938
My system struggles to break 250w from the wall and that's with an HD6850 and Q8300 @ 3GHz and a bunch of HDDs.
His system will probably be more like 200w from the wall, or something under 200w actual, so even a cheap 400w should manage 50% load.
TemjinGold
3,050
65
Agreed. My system can't pass 220watts from the wall at gaming load. Even if he has a shit supply that can only do 200 actual watts, he'll be fine.
Wayfaerer1
15
Yeah I mean it's a gateway pre-build desktop. Model is LX6810.
So, probably not the highest quality power supply in there, but Im hoping the 400W supply will be enough to run the 5770 when I install it later today.
Wayfaerer1
15
Link to the PC model I have - http://www.gateway.com/systems/product/529668232.php
