Originally posted by: jkresh
JackBurton you didn't mention for 3. That "HDMI is digital, component is analog" and this device actualy converts the hdmi to vga (which is also analog) so thats another argument of his thats kind of ridiculous.
BIgapp I guess if you are spending $3000 on a scaler and are connecting to an old high end crt projector then this could be useful (assuming the projector has vga) , but your scaler actually has component inputs (and at least until 2010 those are fine for hd-dvd and blue ray) and no vga input so this device wont help you.
You make me laugh big time !!
DIGITAL and ANALOG makes difference over the cable LENGHT !!!
If you have 5 meters of DIGITAL cable you have no loss, if you have 5 meters cable of ANALOG you have big loss.
The longer the cable is, the worst quality you get at the end with ANALOG !
So if you use your brain, you will find out that you can run DIGITAL cable to your display and then output ANALOG with the SHORTEST RGB ANALOG LINK that you could get, means BEST quality possible ! This is what HDfury is doing
Your comment just show that you believe this stuff connect to the SOURCE and not the display, otherwise you will have understand since a while that this device allow you to keep the digital link
