Will an 8X AGP card work in a 2X AGP motherboard?
HybridSquirrel
6,161
try it. if it doesnt work it doesnt work. it might be able to slow its self down enough to work on 2x
JackBurton
15,993
14
I don't have the card yet. I have to order it. But I don't want to get it home, find out it doesn't work, then have to RMA it. That's why I'm asking first.
LiekOMG
1,362
Generally speaking, if the card uses the old style AGP plugs (3 separate rows of pins, as opposed to 2 rows for AGP 4/8x), then it should work.
Peter
9,640
The 9250 chip can still do 3.3V signalling as required for 2x AGP mode, and the card does have the 2nd key notch to prove it. That'll be a Yes.
JackBurton
15,993
14
Awesome man. Thanks!
Steve
15,946
11
Okay.
I've got a Radeon 9600 and an old Pentium II board.
Want to try it?
CKTurbo128
2,702
An AGP8X card will work in a AGP2X slot, as long as the AGP8X card has a universal AGP connector (3 rows of pins). AGP8X cards like the GF FX 5XXX series, 9500/9700, and 9800 (R350 core only) all have universal AGP connectors.
Okay.
Want to try it?
I don't think it will work with your old PII board. The last I heard, all Radeon 9600 cards lack a universal AGP connector (4X/8X only), so it probably won't even fit into the slot.
Brian48
3,410
2x boards are pretty old. Even if it did fit, I'd be concerned about the power specifications of the motherboard's AGP port.
JackBurton
15,993
14
Well I guess I'm gonna find out in a couple of days. ;)
Peter
9,640
Not a problem. The Radeon 9250 is a low performance, low power consumption chip that doesn't even exceed the AGP 1.0 power allowance.
JackBurton
15,993
14
You're a wealth of knowledge. Thanks Peter! :)
