Will adding more memory to current system ruin my dual channel setup and Overclock settings
TheRoots
I'm looking add more memory to my system because I'm moving from windows xp 32bit to vista 64bit. My question is If I fill up my last 2 slots with a another pair (2x1gb) will it stop it from running in dual channel and will i experience problems with my current overclock.
The ram I'm looking at
http://www.newegg.com/Product/...x?Item=N82E16820231087
http://www.newegg.com/Product/...x?Item=N82E16820231171
Current System
Gigabyte GA-965P-DS3
http://www.newegg.com/Product/...x?Item=N82E16813128012
Intel Core2Duo E6400 Conroe 2.13Ghz @ 3.2ghz
http://www.newegg.com/Product/...x?Item=N82E16819115004
G.Skill 2GB(2x1gb) DDR2 800(PC2 6400)
http://www.newegg.com/Product/...x?Item=N82E16820231065
EVGA Nvidia Geforce 8800 GT 512mb
Denithor
6,298
23
It won't interfere with dual channel, it may or may not mess up your OC (depends how nice the motherboard plays with the RAM).
Better option would probably be grab a pair of 2GB sticks & sell those 1GB sticks.
EDIT: Like these - G.Skill 2x2GB DDR2-800 for $45 shipped.
imported_Scoop
773
It didn't screw with my OC setup, though I had to (like most of) bump up the MCH voltage a notch or two. Four modules also give you slightly worse performance than two.. which you can find out with Everest :)
