- May 24, 2001
- 3,114
- 1
- 0
Originally posted by: SparkyJJO
short most likely, what is the mobo sitting on
the antistatic bag and thats on top of the padding from the box then a chair.
i wasnt planning on running it like this for long was just checking if everything worked.
Originally posted by: sjandrewbsme
How are you powering up? If you short the PWR-ON jumpers for a moment, it will work. If you leave them shorted (like with a jumper), you will boot up and then power right back off.
I typically start my board (outside of the case) with a screwdriver or paperclip.
What does it mean if when I go to turn it on the fans just spin up for a second then shut back down?
ram, check
video card, check
power supply, check
Thats all thats plugged in as of now.
Originally posted by: Roguestar
Put one stick of RAM in slot three and try and boot. If that works, go into the BIOS and change the VDIMM to +0.3V.
Thanks. I will give it a shot when I get home.
anti-static bags are conductive, not insulators. Put it on cardboard.
EDIT: Machines run just fine out of the case. My crack rack ran out of cases sitting on shelves in the garage for months.![]()
Any news?
