Question will a 6 pin part of a PCIE power cable for for a 6 pin ATX CPU power plug ?
Markfw
May 16, 2002
27,139
16,035
google says no, but I have a friend that says he is using it, no issues.
Required on a
MZ33-AR1 motherboard​
Help !
bba_tcg
899
523
computerguyonline.net
No what ??
You asked if a 6 pin part of a PCIe cable would work for a 6 pin ATX CPU power plug, didn't you? Or did I misunderstand the nearly incoherent question?
Edit: though it would make more sense for Gigabyte to have used the PCIe plug, which I've seen used for many different things on different motherboards. In which case the answer would be "yes" if I correctly guessed the true intent of your original question.
Markfw
May 16, 2002
27,139
16,035
Gigabyte answer from their technical department. Yes the PCIE plug is designed to be used.
