Question Will a 3.5" HDD enclosure work with optical media?
Perene
168
10
I am currently looking for one like the Vantec, for attaching with 5.25 drives:
But I was only able to find 3.5 HDD enclosures, SATA/IDE. My question is simple: will these work somehow with Blu-ray/DVD drives? Or even if they work, there's a risk the drive will not fit?
Example:
Perene
168
10
You are right, I just checked, I really need something like the Vantec, because the Pioneer drive has these measurements:
148 mm(W)×42.3 mm(H)×181 mm(D)
Or 14.8 cm WIDTH, 4.23 cm HEIGHT, and 18.1 cm DEPTH. And the Vantec fits them all, but not the 3.5 HDD enclosure, perhaps only 1 of the 3. We need to take into account the enclosure capacity and the drive itself.
BoomerD
66,104
14,506
I have one of those I've used for more than 4 years. Fits my Samsung DVD drives perfectly. In a pinch, I can use it for HDDs and SSDs as well.
