the unknown
So is the Maxwell BIOS Tweaker the one to use? Any walk-throughs you would recommend? Also I'm guessing the brand is unimportant.
TBH I don't think it really matters. It sounds like all you're doing is dabbling in the extreme limits of what your hardware is capable of, which is fine if that's your thing or you're going for a benchmark high score or what not. For everyday gaming I tend to sacrifice that last 2-3% for absolute stability. I've been running Afterburner on a 970 for 6 months now with no issue because of this. Remember that your operating environment is variable (ambient temps change, dust can build up, loads change, etc.), I don't really see the utility in pushing your gaming system so hard for an extra 2%, and personally would prefer the better power savings.
Good advice.
I don't even load an OC profile in AB unless I am actually gaming. Stability is more important than (maybe) 1-2 more fps.
Edit: Of course this is someone who hit a hard-wall in OCing at 1550. I guess I could try really maxxing voltage, but its just not worth it for maybe 10-30 more mhz...
Its amazing how much more stable I have been without using AB for OCs. After modding just the power profile my gtx 970s both do 1550 boost with 4000 on mem and has been crazy stable. I couldnt do 3800 on mem without issues in ab stock. All I modded was the mem in the first page and the power profiles.
After going back to the old driver and modding both bioses similarly both pcs are completely stable. Asics on both cards are 71 and 73.
Were you running your card at stock speed when the crashes occurred? What kind of crash were you having (CTD or TDR)?
AB has been a source of instability for me in StarCraft 2, even at stock speed. There are several threads going on GeForce/Blizzard forums about the game crashing spanning several generations of cards over the years. It's an unsolved problem and I think AB might be the culprit.
By the way there *IS* a solution for those who don't want to or can't mod their bios: Gigabyte OC Guru. It works also with other brand cards since you can specify an "offset" minimal voltage that is applied. This can be used as a workaround to avoid crashes at lower clocks.
Even if you are not overclocking, running Afterburner along to monitor your video card can induce instability.
It's not much of a problem for games that can stress your video card, but load a game that isnt too demanding, and the display driver will crash when the card tries to underclock itself.
Is this why ONLY SOME of my games are locking up(black screen but with audio on some) with my gtx 980 classified? I tried numerous drivers and still have this problem?
I am not using AB to overclock but i do like to use it for the OSD and fan profile and on some games(mostly older titles) i get a lot of black screen lock ups?
and the only way to get out is to re-boot the tower.
Ps, My gtx 780ti superclocked does not do this and i know the 980 classified is not a bad card because i can play games like watch dogs for 8 hours straight without a single crash.
I can tell you that I know I am stable at 1506 (1519 on a nice day) 🙂 at 1.200V with my EVGA.
If I use the default unaltered bios and then I use A/B to get my max clock to 1506 I get a crash even *starting* Heaven Benchmark....simply because the card(s) take a tiny fraction of time to "clock up" where they jump from a lower (non-stable clock) to the stable max boost. But even this tiny amount of time at a lower clock is already enough to crash.
Another way to test is apply your (supposedly) stable OC with Afterburner, say +150 or more, and then run a game or Heaven Benchmark at 70% power target. This also crashes.
I am not really "blaming" A/B, it's just the way how adding clocks with ANY external tool (Afterburner, Precision, NV Inspector) interacts with Boost.
Hi Flexy, do you think your post could be related to what I was experiencing?
With my Dual 980 Ti's I overclocked using Precision X to +150 MHz Core and +250 MHz memory, all benchmarks and stress tests ran just fine and temps were fine. But when I was watching movies using PowerDVD, I would get random crashes.......do you think this is related to the concept that you are talking about here?
When you see the crashes, if you have GPUz running, do you see the card throttling? I need to test this out on my system to see if I can spot the system throttle a bit. I'm honestly thinking about flashing a custom BIOS that ups the max system wattage to 150%, which I think would allow my overclock to run just fine without throttling...
It did throttle bro,When you see the crashes, if you have GPUz running, do you see the card throttling? I need to test this out on my system to see if I can spot the system throttle a bit. I'm honestly thinking about flashing a custom BIOS that ups the max system wattage to 150%, which I think would allow my overclock to run just fine without throttling...
Not sure but I guess what you said makes sense since these video players don't seem to stress the GPU so much. Mind you I am running MPC-HC with madVR + LAV/CUVID (AKA CUDA)That's not what I expected, actually. Util PerfCap means it saw no reason to clock higher (this is based on the GPU utilization. If GPU utilization rises a lot higher, the perfcap reason will end up being PWR, VRel or VOP.)
I assume the throttling you're referring to is at the very start on the core clock?
Do my overclocking settings seem right though?
