My room description had nothing to do with Chips, re-read it. It was an example of how heat is better dissipated over a larger area vs a smaller area. Nothing to do with chips heating up a room, just an example. lol
Thor_Sevan - a chips performance has nothing to do with the amount of watt's it uses. A chips performance comes solely on chip archietecture. Intels chip was developed using fat pipelines to easily scale chips to high mhz/ghz. AMD's chip has fewer and smaller pipes which allow it to perform better, but not scale as high. You really can't compair different mhz/ghz chips to get a heat comparision just because they do not perform the same. The reason that AMD produces so much heat is because of core size and their lack of a heatspreader. Just cause they perform better does not mean they are as functionally sound as Intel chips for heat dissipating.
Basically this is all pointless. But my original point was that, clock for clock - chip for chip, Intel chips do run cooler because of their core design and thermal protection design. Most Intel chips i see people talk about here seem to run about 10C less than AMD chips. Those are real world numbers
