Why no info on Intel's next microarchitecture?
willfr
33
41
Correct me if I'm wrong, Intel's first chip on the 10nm process will just be the Skylake/Kaby Lake microarchitecture again. The chip AFTER that will be the new design. I can't find any info about it though! I saw a tweet last month that said it really won't be possible to run Windows 7 on it because it'll be so different (apparently Windows 7 does run fine on Kaby Lake even though it's not officially supported)
Sweepr
5,148
1,143
Both Coffee Lake (14nm+ / 14nm++?) and Cannonlake (first 10nm product) are based on new cores.
lolfail9001
1,056
353
Are they? Last time i checked Cannon/Coffee Lake to Sky/Kaby Lake are basically what Broadwell was to Haswell.
The first next new arch is Icelake.
coercitiv
7,470
17,849
This is news to me if true.
Why news? AFAIK Cannonlake is a tick from Skylake, the core will see some improvements. If one of our forumites is right regarding Coffee Lake, we may see the architectural changes sooner than Cannonlake, since Coffee may just be Cannonlake on 14nm.
That having been said, if the above is correct, expect Cannonlake cores to be a small change, just like we saw with Ivy over Sandy, Broadwell over Haswell.
Edrick
1,939
230
I read "based on new cores" to imply a tock. Especially since that is what the OP was referring to. Icelake should be the next tock. I do not think there is any doubt that Cannonlake will be a tick with some small changes.
I would not say that Ivy was based on a new core over Sandy for example.
Maxima1
3,549
761
The slides show Cannonlake coming first, and that's not surprising at all because the H and ULV CFL quads replace SKUs that came later, and Intel has an incentive to roll out the weak and low core count SKUs first.
coercitiv
7,470
17,849
I read "based on new cores" as the opposite of using same cores, as the OP implied Skylake == Cannonlake from an arch point of view.
Indeed, I remember making the same wrong assumption before reading one would be used in mobile while the other would go in desktop.
Edrick
1,939
230
If Cannon remains a tick form of Skylake, then yes, Skylake == Cannonlake from an arch point of view.
coercitiv
7,470
17,849
Was Ivy Bridge the same as Sandy Bridge? Broadwell same as Haswell? Both ticks showed IPC improvements, albeit smaller than tocks.
jpiniero
17,146
7,532
Given the delays, I am assuming that Intel is bringing in some features from Icelake. It may only be just the FIVR and the IGP's fixed functions.
Edrick
1,939
230
From an architectural standpoint, yes they were. Small tweaks coupled with a process shrink, coupled with some added instruction sets.
Sandy, Haswell and Skylake were new architectures (tocks).
Reactions: wingman04
superstition
2,219
221
101
I thought I read an article here that said tick–tock is no longer official nomenclature (one can only hope).
witeken
3,899
193
Borealis7
2,901
205
word is on Oct 30th there will be a presentation of IceLake architecture in Haifa. we might get some leaks after that.
Reactions: cytg111
2,012
That'd be awesome. It's going to be a long time before we get a new, interesting CPU architecture from Intel, so it'd be nice to get some details on it ahead of time.
willfr
33
41
I think we can expect a good step forward in graphics performance, Intel really needs that
SAAA
541
So it's been a week and some... no news? I'm dying for any rumor right now... and I'm pretty disappointed by the lack of information given Icelake should have been released in 2017 if not for 14-10nm delays, but the underlying architecture must be ready if not complete by long now.
I don't see Cannonlake as particularly interesting either because it should be just more cores (10 years of quad core would have been excessive indeed) and little if any IPC increase, same as Ivy and Broadwell.
Also this, gen.9 was good but the real problem looks to be performance/mm^2 and that didn't improve much with all those generations. The die area went from most CPU to most iGPU and it's still trailing below mid-low range graphics, that's unreal.
