Originally posted by: WinkOsmosis
Originally posted by: bR
Front brake should be enough according to
this guy 😀... since at maximum braking the rear has minimal weight and probably wont slow you down enough. If anything since im right handed i would probably flip over since i'm not used to modulating with my left.
Interesting. My seat is directly over the rear tire, don't know how all of my weight is somehow over the front...
During braking... all your weight shifts to the front... just like how it is in cars. Ever noticed that when you brake hard on a car you get pushed against your seatbelt?
That's not the reason for "weight shift". You are pushed against the seatbelt because the car is decelerating you. The increased force on the front wheels is because of where they are... lower than the center of gravity. If someone throws a ball at you and you glance the botton of it with your hand, it will rotate because of the same force imbalance. If you had an air brake on a car extending upward, the weight shift would be to the rear.
But on a bike you also have room to move, and that might make a difference.
