- Jan 31, 2001
- 649
- 0
- 0
Well put this simply here is my setup :
CPU : 3770k
Mobo: Asus z77 sabertooth
Cooler : noctua nh-d14
Case : CM Haf-X
I did a simple overclock in offset mode using a 45multiplier.
Result: The CPU runs at around 74-79degrees celcius under prime95 load. CPU-Z reports a vCore of 1.36-1.37v. Which I found quite high.
Using the Asus software, TurboV EVO, I went in and manually reduced the VCORE until I hit the sweetspot of stability. I found I could use a 1.27v vcore and have a PERFECTLY stable machine under load. Obviously I get much better temps averaging 10 less degrees (64-69degrees celcius)!. I'm very happy with those temp as I'm planning on delidding it soon and should get even better temps, and I'd hope to get a stable 4.8-4.9ghz perhaps.
I'm a little bit of a beginner here I guess because I really don't understand this. I though offset mode would automatically choose a reasonable voltage to ensure stability? Why is it overvolting so much as it clearly does not need 1.37v
I know there is a +/- offset you can set but using a negative offset, my idle vcore gets to low and the system just crash booting or shortly in windows. Plus there is no way to reduce the voltage by 0.1v using offset, it's way to much (the numbers already appear redat 0.02v or something, and I think the MAX value is somewhere along 0.060v).
Anyways, all I'm asking is to be able to set a certain load vcore without affecting the idle vcore(which is 1.024 - 1.032v) and I have NO IDEA how to set this up in my bios. How is it so simple to do in the asus sofware, and so complicated in the BIOS? I don't want to use TurboV EVO because I have to reaaply the new voltage each time I reboot, plus I hear sofware O/C'ing isn't recommanded.
I've done so much reading and search and i just can't find an answer to this question which appear to be quite simple, why is that?
Also I often read people recommand using Load-Line calibration to overclock.. and it just doesn't work at all for me. Currently I have it set to Regular(0%) and if I increase it my load vcore gets higher and higher. I got 1.46v+ vcores using a 75% Loadline calibration. I think LL Calibration is only useful if you run a fixed voltage, is this right?
Damn I hope I'm being clear, sorry if it's not. Thanks for your help.
CPU : 3770k
Case : CM Haf-X
