I only have one last comment/question on this.
if this is so good, so many benefits, why oh why isnt the manufacturer using it, why doesnt the EPA put its stamp of approval on it?
I will not accept any conspiracy theories as evidence of why its not being used...
if I didnt know better, I would think that duracool was the holy grail for mobile air conditioning....why doesnt every manufacturer use it? gotta save them a ton of cash. plus work a heck of alot better than 134A..
http://www.epa.gov/ozone/snap/refrigerants/macssubs.html
Or if that isn't clear enough:
http://www.epa.gov/ozone/snap/refrigerants/hc-12a.html
I love how your answers all link to the EPA. Think outside of the global warming fundies. Not denying your information, but you're not using a credible source.
See how well that argument goes over in a court in a hypothetical scenario where you are selling the stuff as automobile refrigerant replacement on the internet and suddenly get a very inconvenient knock on your door. Amusingly, you use the phrase "global warming fundies" but the entirety of the reason you can't use it is based on direct physical safety.
This thread is all sorts of fail.
We have one guy vehemently claiming that propane doesn't burn (not exactly, but his argument is that it's difficult to ignite)
The same guy is claiming that a substance widely accepted to be non-flammable at standard oxygen levels and pressures (standard being anything you're going to encounter short of building a pressurized container with a pure oxygen atmosphere) is dangerous and going to burn easier than propane.
No one is arguing that it may function better as a refrigerant, but when you try to support that by making wild claims, it's hard to take you seriously.
epa said:Flammable refrigerants pose a special challenge, because air conditioning and refrigeration systems in the US have been designed to use nonflammable refrigerants. They are not designed to protect users, service technicians, and disposal personnel from the possibility of fire. Therefore, the use of flammable refrigerants in existing systems may pose a risk not found with nonflammable fluids.
Although new systems may be designed to provide that protection, they are not specifically designed so today. Demonstrating that a flammable refrigerant can be used safely in current systems, whether existing or new, requires a comprehensive, detailed, scientifically valid risk assessment. EPA has required a risk assessment for flammable refrigerants since the inception of the SNAP program in 1994. An assessment must address potential leak scenarios such as collisions, servicing errors, and disposal procedures. In addition, it must consider ignition sources ranging from cigarette lighters or matches to sparks caused during a collision.
Yes, what you've linked explains why flammable refrigerants aren't approved, and it directly references physical safety.
And no current automotive systems are designed for those refrigerants.
The reason you can't use them is because of the physical risk, nothing to do with anything else.
It's explicitly stated on that page.
Yes, things must meet those other standards as well, but that's not why you can't fill your car AC with propane. That's rejected on the flammability grounds. I'm not sure what you're trying to get at as the source you're citing explicitly agrees with me. It says the words ozone, and warming so suddenly you're blinded to what the source actually says?
So basically, epa conspiracy theories and if I don't accept them, I have blinders? Ok.
Fair enough. I think that's the extent of the usefulness of this conversation in light of that info 😉
More power to you then (I can admit when I'm wrong, and it looks like on the legality in some circumstances I am), but stop trying to claim that the risk is less than a non-flammable compound.
How about this stuff, invented by a mechanic in Hawaii http://www.hcr188c.com/default.aspx just the energy savings alone would be staggering, they are already making compressors for it and it can be used in existing R-134a systems. He's up against global billion dollar company's (DuPont), that might be the only challenge left, amazing that you only need about 30% of this blend vs R-134a..
My truck had been rigged that way when I got it. I assumed there was a failure in the PCM, it controls the AC along with a ton of other functions.at that point, hard wire the compressor and have it run non stop 😉
Your 1st post and you necro a 6yr old thread?, you won't be here long.Have you changed out the winter Freon with summer Freon?
