Why Don't Some People Get It?
Brovane
6,376
2,579
If you want a good site on Crude Oil and all sorts of statistics check out this site - http://www.eia.doe.gov/neic/quickfacts/quickoil.html
You can see how the US uses all of its crude oil imports and all sorts of fun data like in 2007 the US imported 3,656,170,000 barrels of Oil and 1,968,765,000 of that oil came from OPEC. So over half of US imports come from OPEC countries.
All sorts of fun stats like the US used 179,005,000 barrels of oil in 2007 for Asphalt and road oil usage.
AccruedExpenditure
6,960
7
Originally posted by: sandorski
Originally posted by: AccruedExpenditure
Gas will be under 3 dollars a gallon and oil under 60 dollars a barrel by 2011
/thread
...and if it isn't?
It will be, i've got a number of running bets with friends that it will be, if it isn't, i'll be down a couple grand.
sandorski
70,783
6,340
/thread
...and if it isn't?
Perhaps you should Hope you're right, but live like you'll be wrong. ;) That way you'll limit your losses to just the Bets.
Dec 30, 2004
12,553
Originally posted by: Eeezee
Originally posted by: tenshodo13
Running out of oil is one of the best things in the world?
http://en.wikipedia.org/wiki/P...s_based_on_refined_oil
Oil isn't just used to make gas, theres a crap load of products created from oil
Which is EXACTLY why we want to get on alternative sources of energy. This has been well-known for a long time.
If we stop burning oil, then the cost to produce these other items goes down (less demand). Running out of CURRENT supplies of oil IS the best thing, because it would force us to only use oil for products that require it.
We don't require oil for fuel, it's just cheap and effective. We REQUIRE oil for many products. Thus, if we run out of current supplies, we'll be forced to stop using oil as fuel.
WOW. So much freakin fail, you are simply dumb.
http://static.howstuffworks.co...l-refining-diagram.gif
You only get so much material to use for plastics out of a barrel of oil. Not using the oil for fuel doesn't suddenly free up oil for plastics and synthetics.
I hope soon enough the gas prices will get high enough that the greenies will say "screw it, I want cheap gas, you guys can drill Alaska".
Dec 30, 2004
12,553
also, this company:
http://www.amyrisbiotech.com/
was featured in PopSci recently.
They say they've got a way to develop gasoline from sugar using some enzyme (which uses CO2 in the process). They're not publicly traded so I doubt they're lying for funding. They've got plenty of that AFAICT.
Take that greenies, science solves all. Get your nasty government out of my economy.
Baked
36,052
17
Maybe you should ask congress why they're paying farmers to burn their crops and pretend like we're making progress on alternative fuel. Oh wait, we're not. I wish people drive steam powered automobiles. Clean and cheap!
Savarak
2,718
we need innovations in effective and minimally invasive extraction of shale oil...
Eeezee
9,922
Originally posted by: Cogman
Originally posted by: eits
Originally posted by: Mo0o
Unless we dont come up with good alternative fuel systems by the time it runs out
the technology is all already there... i believe that this administration has been dragging it's feet on alternative fueling ever since 2001 when high horsepower hydrogen-powered cars by bmw were showcased in the u.s. because it was put in power by the big oil companies.
Tell us, oh mighty one, what is the alternative? solar? Wind? Ocean? Ethanol? Hydro? Hydrogen?
Let us dive into some alternatives.
Solar, expensive, dirty, and requires rare minerals, in some instances it doesn't produce more energy then the cost to manufacture. A long standing public myth deems this fuel source as "Clean" because it has low operating costs. This myth fails to take into account disposal and manufacturing which more then destroys this as being a "Clean" source. Lets not forget that it only operates during the day, in which case expensive batteries and converters (DC to AC) would be needed to supply the world with power at night.
What you know about solar power was true 20 years ago. Times have changed.
Solar power does NOT require photovoltaic cells for generation. This is but one option. A more efficient (cost-effective) method is to essentially use mirrors to boil water, which runs a turbine. No rare materials are required (unless you consider mirrors to be particularly rare). Allow the steam chamber to be a nanotube coated surfaces (environmentally friendly) for maximum efficiency.
Solar power does NOT require batteries for supplying energy at night. In the regions most ripe for solar power, cloudy days are rare, so there's an automatic plus. These regions also happen to be home to some of the largest abandoned mine shafts in the world. Using molten salt (ie filling the unused shafts) as an energy storage medium is a well-understood cost-effective process.
HVDC transmission lines are an effective, nearly lossless (less lossy than standard AC lines) method for transferring the power from place to place, and the AC converters are actually a lot cheaper than you'd think.
I suggest you actually read up on modern solar power. Newscientist and Scientific American each did a series of very informative articles regarding the latest advancements in the last 5-10 years. In 50 years the US could be running on over 90% solar power for its electricity if we start laying down the infrastructure and investment NOW. The initial cost is high, but over a long time it will be cheaper to run on solar power than coal (which has been seeing a price spike in recent years).
Today, solar is just slightly more expensive per kW/hr than nuclear, which is only slightly more expensive than coal (factors of two). Coal is going up in price. Nuclear is a PR nightmare despite being safe and cost-effective, but its price is pretty much Solar is going DOWN in price every year as more research is conducted.
frostedflakes
7,925
exactly, take a look around your house...or hell even you workstation/home office....see all that plastic (computer case, keyboard, mouse, monitor enclosure, the cd's/dvd's that your software comes on, your cable/DSL modem, your printer, any external drive enclosures) anything made out of plastic pretty much requires oil as a key component....so when you say that it would be good for the world to run out of oil...think about everything you own that is made of plastic.....running out of oil may not be such a good idea.
Plastics don't necessarily have to be made from petroleum, though. As with gas cars, up until recently oil was cheap, so nobody bothered researching alternatives. Now that oil prices are on the rise and there is more of a push for greener products, though, I think a lot of money is being dumped into bioplastics research. With oil prices increasing and more focus on bioplastics research, it's only a matter of time until they are more cost effective than their petroleum-derived equivalents.
Eeezee
9,922
WOW, you are simply a retard. The fuels you showed in your diagram can all be used for OTHER PURPOSES. Gasoline does NOT need to be burned in our cars. It can be used to create derivative products, just like the rest of the items on your diagram. Congratulations, you're a moron.
Also, by using the word "greenie" you've revealed yourself as a douchenozzle.
Edit: Furthermore, less gasoline consumption = less demand for oil = LOWER PRICES PER BARREL = lower prices for all products derived from oil
You == FAIL
Jeff7
41,596
20
One of my favorite things head wrt the gas issue was at a warehouse I worked at during a few summers:
"What the government should do is just set the price of gas back to $1/gallon - force everyone to sell it at that price."
He was the shift manager and not exceptionally bright, so it probably would have been unwise to tell him that that's been done before, and that it was called "communism."
The sooner we find some alternative to oil, the better. It's a finite resource, and no amount of complaining or propaganda is going to change that.
Kadarin
44,296
16
Before we develop and deplete our own reserves, we need to first purchase as much as we can from the Middle East. Why? Much of OPEC is potentially hostile to Western interests and ideology.
1. Buy as much of their oil as possible, while retaining our own reserves.
2. Make sure OPEC countries do not spend their profits on sustainable infrastructure where possible.
3. When OPEC countries run out of oil, US still has reserves and is sitting pretty.
4. Potentially hostile culture loses main source of income, and thus becomes ineffective on the world stage.
Long-term geopolitical thinking.
frostedflakes
7,925
Then we'll have other countries attacking us for our oil, perhaps WWIII (oil countries vs. non-oil countries). Great idea!
The way I look at it, humanity is going to be pretty screwed if we don't ween ourselves off crude. Turning it into an "our oil, their oil" thing is just silly IMO.
Kadarin
44,296
16
It's not silly, it's deadly serious. Like it or not, currently world civilization runs on oil, and it's a strategic resource.
But yes, we do need to find alternatives.
frostedflakes
7,925
I'm just saying a few countries hoarding all the world's oil cannot lead to anything good. We'll be sitting pretty... until China decides to send over a few hundred million soldiers to take over our pumps and refineries.
I'll concede it's a pretty far-fetched scenario, but you never know. Wars are waged all the time over valuable resources (be it land, precious metals, diamonds, etc.).
Captante
30,353
10,876
All the people who make their money from oil have been dragging their feet & discouraging developement of alternative energy sources since the first oil crisis back in 1974.
The fact that we still rely on oil as a primary energy source 35 years later is just pathetic.
wetcat007
3,502
Well at least one guy who made billions from oil is investing elsewhere.
http://www.cnn.com/2008/US/05/19/pickens.qa/index.html
frostedflakes
7,925
Meanwhile, Brazil started investing heavily into commercializing ethanol, and can now boast an EROEI of 8:1 on their ethanol production. One could argue that sugarcane is a higher-yield carbohydrate source than anything we can grow here in the states, but if we had started investing into research decades ago, who knows where we'd be by now. I'd imagine we would have already figured out cellulosic biofuels, and could be turning non-food crops (switchgrass, for example) and waste plant material (grass clippings, corn stalks, expired vegetables, etc.) into ethanol or other biofuels.
0roo0roo
64,795
84
exactly what i was thinking as well:)
its our reserve.
is not, unless you believe in conspiracy theories. hydrogen has plenty of problems. building a one off prototype or a small fleet for show is easy. doesn't mean its viable on a large scale.
alkemyst
83,769
19
except oil is much like diamonds...the only real scarcity of it is that that's created by those that produce it.
JulesMaximus
74,578
982
Originally posted by: rocadelpunk
What exactly would you have against drilling our own oil (putting jobs here) and not having to rely on foreign sources? Sounds like a great idea to me, especially since as far as I know there is just a shitttttton of oil in the U.S. (I'd have to ask my friend where/how much for specifics). Also, I don't know if the country could stand another *oil line debacle*. I wasn't alive during that time, but from what I've heard...morale was quite low, people felt like a second rate country and things were just...bad. If we got to that point, I'm sure nobody would care what environmentalists thought.
Would you want oil wells pumping outside your bedroom window 24/7? What kind of quality of life does that give? You don't care so long as you can fill up your SUV that gets 15mpg for under $50?
Everyone blames environmentalists but really we should blame ourselves for the decades we've been doing nothing but handwringing and burying our heads in the sand somehow telling ourselves that it is our right to be wasteful.
ElFenix
102,402
8,574
True, the US purchases little Oil from the Mid-East, however due to Supply/Demand US purchases of Foreign Oil simply forces Asia/Europe to buy from the Mid-East. Add in Market Prices being largely set by OPEC and no matter what amount of Oil the US gets from the Mid-East the US remains largely at the Mid-Easts' mercy.
This post has nothing to do with blame, but everything to do with Market realities.
and it'd be that way if we got 100% of our oil from here
moshquerade
61,504
12
56
This guy doesn't seem to mind
Indiana man drilling for oil - in his backyard
2 days ago
SELMA, Ind. ? An Indiana man is capitalizing on high crude oil prices with his own oil well - in his back yard.
Greg Losh tells WISH-T-V in Indianapolis the well that produces three barrels of oil a day is "a money-maker."
He says it comes from the Trenton oil field that fuelled growth in east-central Indiana more than a century ago.
He says it costs about $100,000 to drill an oil well, but that at today's prices, it's worth it.
Losh expects to drill four more wells on his property in the town of Selma, about 90 kilometres northeast of Indianapolis.
Losh says the oil is stored in a tank and transported to Ohio for sale.
The well also produces natural gas to heat his home and several others.
http://canadianpress.google.co...N-WslQIEIrRXPoh1DdFc8g
Xavier434
10,373
Are treehuggers really to blame for our lack of participation when it comes to drilling for oil in areas like Alaska, Antarctica, and various other places? How does this all work out economically? Is it too expensive to drill the oil in most of these locations?
I do blame treehuggers when it comes to Nuclear power though. I would like to see us use Nuclear energy a lot more. I'm not green enough to care about the waste considering our current methods to dispose of it. Those methods are good enough for me.
