Why don't people put weed in cigarettes?
Originally posted by: Regs
So next question: what does the water in a bong do?
Water + fire = Steam and vapor. You figure it out.
Umm, the water doesn't heat up in a bong. As mentioned above it is supposed to cool the smoke. Some people put ice in there as well or liquor from the freezer. But since you can draw huge hits from most bongs any cooling effect is usually negated by the sheer amount of smoke. 🙂 lovely
cigarette paper burns too fast, wastes the doobage. Why would you do that? It still smells, you're not hiding anything from anyone
Originally posted by: nakedfrog
Fairly common in Europe is a method that entails including some sort of cardboard or something at the end to prevent said problem.
Aye, it's called a roach.
[Edit] Also stops your lips getting burned too easily.
