Anubis
You guys are stingy uploaders. Geeze. Thank goodness for private trackers.
I upload a lot actually I just use a different computer for Dling vs Seeding.
once things get DLed files get moved to start seeding
Some posts on here are shocking. Really have to wonder if people know what they are talking about on here...
	THERE IS NO NEED FOR A DAMN PORT TO BE OPEN!!!
I don't have a port open and like I said I get 2 MB/s download. Opening ports for that hackware and your asking for trouble. It's most likely his network.
So since you are the best football player you should be able to win the world championship of chess right?Says the guy responsible for this thread......
http://forums.anandtech.com/showthread.php?t=2408201
Anything and everything involving outside networks needs to have ports open, on one side at least.
The reason you get 2 MB/s download is problably because you have UPnP and/or NAT-PMP enabled on your router which in itself is asking for even more trouble.
As I said that's probably because you're the one initiating the connection. If others want to connect to you then somewhere you're going to have to open a port. I think you're confusing connecting to peers and the ability to download/upload. These are two distinct things and the latter can happen regardless of who initiates the connection.
Here's a very good article on how to get rid of all ads and toolbars in µTorrent. http://www.ghacks.net/2013/06/28/how-to-get-rid-of-all-ads-and-toolbars-in-µtorrent/ This only takes a few minutes to do and the changes will remain when updated.
NAT-PMP then. What you are saying is imposible.NEGATIVE. Universal Plug and Prey is OFF! It's been off for the eight years I have had this router flashed with DD-WRT!
	Did you actually read that link?Negative again. There is no, NO port mapping or UPnP on this WRT54GL flashed with DD-WRT. I can tell you that the uTorrent connection icon says everything is fine. In fact here is a screen grab of using uTorrent with a VPN that doesn't even use port forwarding.
You can and should block all ports inbound to your network , but only allow outbound connections.
In post #21 I gave this link. Read it! https://superuser.com/questions/91994/how-does-seeding-in-utorrent-work-if-i-dont-forward-any-ports
Then your connection is not going thru your connection but it is going thru the VPN...Completely different scenario.+In fact here is a screen grab of using uTorrent with a VPN.
Sure would be nice to have the OP report back.
One of the reasons uTorrent and other similar software work: http://en.wikipedia.org/wiki/Hole_punching
Negative. I was hosting a 9/11 DVD and had no port open at all. Imagine that. LMAO!
Whatever. If you know basic networking, you know it is impossible for it to work correctly and the way it should.I have used my regular IP too so there's no hole punching. You don't need to open a port to use uTorrent!
I do not understand why people make up false statements on the internet to confuse other people.
I haven't forgotten the topic, I was just seeing what last few posts are saying, but I don't have any clue about port forwarding I am afraid to say.
Anyway, I have noticed something in past couple of days. I never actually monitored the desktop while a torrent downloads, I just keep doing my stuffs. But this is kinda interesting, or not, whatever. The torrent is actually being downloaded at full speed, because I noticed the NetWorx graph at task bar showing graph of full speed, so I used that software's Speed Meter and it showed that the torrent was downloading at full speed. But at the same time uTorrent was showing less transfer rates (upload and download speed combined). So I am confused as where is the rest of bandwith is going? I am sure its used by uTorrent too, but I don't know for what purpose.
I took a screenshot,
You can see qBittorrent shows 201 KB/s (194 download and 7 upload) while NetWorx shows 220 KB/s, which is almost full speed of my plan (230 KB/s).
So in this sense uTorrent was actually not downloading at any lesser speed than qBittorrent.
By the way, thanks a lot for that link which demonstrates how to make uTorrent AD free.
And about that port forwarding thing, I am confused with all the discussion. What should I do? Currently it's at default setting obviously.
