Mrburns2007
- Jun 14, 2001
- 2,595
- 0
- 0
Originally posted by: Pariah
There are at least 5 SCSI drives that exceed 54.3MB/s, the X15-36LP topping them all at 60.5MB/s. This drive was released last August, and the best IDE can do 2 generations later is sub 50MB/s. The next gen X15 due in a couple of months is expected to break 80MB/s.
Edit: Also keep mind, that due to the smaller platters in SCSI drives, they decay far less than IDE drives do. The WD that hits 49MB/s, but drops all the way down to 29.2MB/s on the outside, while the SCSI drives drop to about 45MB/s, less than 5MB/s slower than the fastest part on the WD drive. The difference between 45 and 29 is pretty significant.
Yep, scsi is better but to expensive plus you need a card because there are no good motherboards with scsi built in. The new 10K Maxtor will hit 72 MB with a low seek 4.4 ms, have no idea how much it will cost though.
