BladeVenom
I've only had one go bad. I've mostly used ATI cards, and video cards have been one of the most reliable parts of a computer for me. I also usually don't overclock my video cards.
I don't overclock either - I run everything within spec. I've owned 2 video cards prior to this, and neither went bad (Radeon 7000, Radeon 9600 Pro), though neither ran nearly as hot as this 6800 GT.Originally posted by: BladeVenom
Originally posted by: jiffylube1024
VRAM is pushed to the limits; system memory much less so. Just looks at the speeds they are released at - when Video memory was going past 1 GHz, system memory was between 200 and 400 MHz.
And as for the 6800GT being released before the thermals were under control - it's been that way pretty much since Transform & Lighting was introduced, and particularly since the FX 5xxx series of video cards. It became an arms race between Nvidia and ATI for the performance crown, and the definition of "acceptable" thermals and lifespan for most modern graphics cards would make an Intel or AMD (CPU division) engineer cringe.
GPU makers have the added constraint that, unlike CPU's, their GPU's face upside down (in most tower cases), with much inferior cooling to CPU's, and not the most ideal location to dump heat (below the GPU or outside a tiny hole in the back of the graphics card).
Originally posted by: Zap
Originally posted by: Turbonium
On the other hand, I've virtually never heard of system RAM (run at stock) going bad.
You've obviously never owned any Crucial Ballistix DDR2 from the past few years. (and bryanW1995 beat me to it)
I've also had some Corsair and A-Data RAM DDR RAM die on me.
Note that this doesn't mean I've stopped buying those brands.
Overclocked, or within spec?Originally posted by: Meghan54
Quite true.........Crucial Ballistix is the brand I've had the most failures with, but I've also had a set of Mushkin Redline fail, also some Buffalo Firestix, several sets of Kingston HyperX, as well as a few sticks of "generic" RAM by Corsair, Crucial, Kingston, G. Skill, and no-name.
That's got nothing to do with it. VRAM is rated to run at a speed and that's the speed manufacturers build cards to run it at. What's all this pushing to the limits none-sense?
VRAm and run-of-the-mill system memory have very little in common to anyone who's wondering. You can't work out a clock for clock comparison.
Originally posted by: evolucion8
I Used to have a 2GB kit of Ballistix Tracer DDR1 500Mhz and both sticks died on me running at 400MHz, one died 3 months later and got replaced and still working fine today, the other one died 6 months later and they didn't had any more of those on stock and wanted to give me cheap and slow DDR 400 with 3-4-4-7 RAM stick as a replacement and wanted me to pay the price difference plus shipping, I said thanks but no thanks, that's why I only use G.Skill 🙂
