Why does Max Pane keep kicking me back to the desktop?
It used to kick me back to the desktop when I had everything on max detail, but it works fine when I set everything to medium..weird.
has it EVER worked? maybe you have the wrong display adapter selected. have you installed new detonators recently? try either going back to older ones or d/l the new ones (whicever situation u find ureself in). maybe try to go from direct3d to opengl or whatever.
just an attempt at helpful thoughts
It works fine on my GF2 and XP, but not on my GF3 XP machine.
I'll try the patch and see if it helps.
Thanks.
