Why does Antec do so badly in Tom`s hardware PSU testing?
Acanthus
19,915
ostif.org
Originally posted by: Technonut
I have mentioned that I can see no use for it. You disagree, but don't actually say what that use would be. What, specifically, would you do with it ? The only thing I can conceivably think of is as a hack for a motherboard that doesn't support component voltage adjustment, but that strikes me as appallingly crude, and the further point that the general failure criteria is a system crash, at which point the ability to adjust the voltage in any direction becomes irrelevant.
Personally, I have enjoyed using PSUs with adjustable pots since Antec came out with the TrueControl. AFAIK, even though the specs on a PSU may check-out fine when testing through the Molex connectors, it is the readings that come-out AFTER the juice passes though the mobos voltage regulation that count.
In many cases with different OC'ed mobos, I have found the voltage below rated specs. This was after checking the mobos voltage regulators under load with a digital multimeter. I corrected this by using adjustable pots on the PSU... :)
With my primary rig, it is very important to have a quality PSU with adjustable pots. The VapoChill compressor and heating elements run on the PSU, along with everything else. My 550W TrueControl, even with the pots maxed-out could not keep up. I ended up using the PCP & Cooling TurboCool 510 and have been pleased. After adjusting the pots, the voltages are stable and above spec under a maxed load. ;)
I thought the new vapochill was powered independantly? If not... wow to no innovation on their part.
It was a huge problem when i was running the original Vapochill on a 2.26B P4.
I was actually considering vapochill as well, looks like Nventiv all the way.
Technonut
4,041
The current models are.... I have the older, Stand-Alone PE that I custom fitted in the Lian Li PC-75B. I had a Prometeia before, and am glad that I never have to deal with the seal-string mounting system again. ;) I use the current VapoChill clam shell mounting system, and am VERY happy with it...
Lithan
2,919
Originally posted by: wyrmrider
Hi Lithan
I have several pcp&C silencer ATX 400 Watt units
They are basically the same as the 510 watt Turbo-Cools with different fans
(these are last series models not current production)
As you noted power supply tests can be rigged by the temperature of the test area and case cooling.
I can convert these 400 watt silencers to 510 watt ratings by swaping fans
Would like to see Tom run his tests at 30 40 50 C
Some mfgs might just overate their units :)
The PS market is so very competitive
We just scrapped some power supplies and found the Capicators ranged from 400 to 2000 ufd- other obvious differences between the quality units and the mass marketed ones. Not to mention the no name units which come with several cases or the "specials" available.
Some PS have terrible EMI/RFI and line noise In and Out The noise that kills hard drives
Remember the fuze only affects the power line side and protects other things on that side
It does not protect your components- that protection costs real money.
A ups WITH power conditioning should be a requirement for any system you do not want to loose- the system or the data We use APC 1500 and up
Wyrmrider
I checked out PCP&C's own specs for the 410 silence versus the 510 turbocool They are VERY different PSU's. Like I said, the silencer has the worst line reg spec I've ever seen on an atx PSU of that wattage.
caz67
1,369
I have never had any issues ever with using Antec PSU. Tom's Hardware, is an average site at best IMO.
furballi
Banned
Apr 6, 2005
2,482
His reviews of the Enermax and Seasonic PSUs were very close to my test results. Unfortunately, my setup will only load up to about 250 watts.
Hyperlite
5,664
Originally posted by: Soldier
Originally posted by: JEDIYoda
Is it Antec that needs to correct issues?
Or does the tom`s hardware people just have no clue?
Theres nothing wrong with Tom's method of testing and there's nothing wrong with Antec supplies as long as you dont load them more than 50% of the supplies rating. They are fine for average non-overclocked systems.
huh?
Gamingphreek
11,679
Originally posted by: Heckler 5th
where can i find the most complete, unbiased power supply reviews/tests on the web?
While they dont do many reviews. Silent PC Review, is hands down the best reviewer out there for PSU's. They are incredibly detailed and comprehensive. They even provide MP3's of what the PSU sounds like at various loads.
Well at least Soldier stopped spreading crap.
-Kevin
bradley
3,671
-Kevin
If you compare Tom's site to Silent PC Review, or Anandtech, then it simply pales and simply isn't worth reading. I'm not even calling his data into question, as much as the conclusions he extrapolates from that data... and the overall impracticality of his tests.
Lithan
2,919
Not calling his data into question? Did you miss his dual core stress test? He flat out lied repeatedly to cover up the mountain of problems and weak performance he encountered on the intel machine. And people who recorded data at short intervals found increases on the intel system that were absolutely impossible. Fugger, an intel developer (If I recall) was telling us how screwed up his test was. He even had the wrong cooling on the intel rig (actually both rigs, but the intel was the one Fugger caught). I believe it was Fugger, though it could have been another Intel proponent who basically told us that none of the problems were intel's fault they were all due to Tom's incompetence. I'm not so sure of that... but let's just say about the only people who could NOT call his data into question are the people who only read his "edited" results. Where he essentially blames everything on Nvidia, as though it's some evil spirit making trouble in his "Laboratory".
bradley
3,671
"I'm not even calling his data into question, *as much as* the conclusions he extrapolates from that data... and the overall impracticality of his tests." :)
Lithan
2,919
Well, personally I think I'd call his data into question more than his idiocy, because his data is more damaging than his idiocy... unless you conclude that his crappy data is due to his idiocy, then his idiocy is the root problem. But I really don't think tom's is worth that much thought. So I just call him an idiot.
raildogg
12,892
572
so just because your a fan of a particular psu and it didnt win in Tom's roundup, Tom's hardware must be biased!
oh the sweet smell of fanboyism
Markfw
May 16, 2002
27,287
16,124
I don't think thats a faid assesment. Antec is well known as being a quality manufacturer. I personally have used at leat 15 of their PSU's in systems I built, and own 10 myself. I have never had a failure, or a problem with one. So the fact that Tom's failed them, could mean the test is flawed somehow, or it was a bad unit (that does happen to the best of them). So to just say that if it doesn't pass and somebody thinks that wrong, makes them a fanboy ? No logic there.
Now if he failed a generic and somebody got upset thats a different story. But Antec is well known.
Avalon
7,571
178
You are calling Antec and Enermax and OCZ "bargain basement" powersupplys. YOu can really just get the hell out of this thread because you have NO clue what you are talking about.
While PCP&C and Zippy are in a league above them (due to higher quality, industrial-like components) Antec, Enermax, and OCZ, are probably the best consumer grade powersupplies you can buy.
Pwned.
-Kevin
Are you 15 years old ? Pwned ? How so, because you spout off with nothing but your uneducated opinion ? Did you read the dual core tests where the OCZ fell on its face, sorta like your lame reply. Reread the Tom's test and you'll see they tested at max rated load for 24 hours, these "consumer grade" power supplies as you call them, are not meant for that kind of work, they are meant for the average non overclocked system and are fine supplies for that as I stated earlier in the thread. Are you claiming otherwise? What would be your experience with these supplies under heavy overclocking? I killed an 480 Antec and an 465 Enermax overclocking an XP Mobile 2600 to 2.6Ghz, where did you successfully use these supplies at those clocks without failure? The PCPC Silencer 410 I now have ran the same system for almost a year and was then moved into my current rig in my sig for the last 6 months. Pwned would be you when your rig locks up 2 hours into the best game of your life because you brought the wrong equipment to the fight.....
You killed your Antec and Enermax supplies because you are a moron. I had MULTIPLE 35w 2400+ and 45w 2600+ XP-Ms fully stable at 2.6 with a cheesy 420 Enlight w/18A on the 12v rail. I had that power supply for two years.
I've had a Sempron 2800+ s754 on a DFI NF3 fully stable at 2.7 with an Enermax 460w until I upgraded to s939. Now I'm using that same Enermax with a Venice @ 2.6, overclocked BH-5 memory, 2 HDDs, fans, 2 opticals, LEDs, and a 6800.
I guess I better drop everything down to stock, because my Enermax is a bargain bin make :roll:
Markfw
May 16, 2002
27,287
16,124
Pwned.
-Kevin
Boy, you are a moron. First we had Duvies Winchester 3000@2.6 on a 300 watt Antec, its first stable OC (but it wasn;t that long I grant you). And I have an X2 4400+ and an X2 3800+ BOTH at 2560 for 2 months, 24/7 with no problems on Antec 380 true power PSU's I SPEAK FROM EXPERIENCE. They are not crap made for non-OC'ed systems. As said earlier, you must have done something else to kill them. And one of them is mission critical as I use it for work. I make over 80k a year as a Senior programmer, so I'm no moron, and I know of what I speak from experience. Grow up !
charloscarlies
1,288
[/quote]
You killed your Antec and Enermax supplies because you are a moron. I had MULTIPLE 35w 2400+ and 45w 2600+ XP-Ms fully stable at 2.6 with a cheesy 420 Enlight w/18A on the 12v rail. I had that power supply for two years.[/quote]
Ditto. I had my XP-M at 2.6 rock solid on both an Antec True 480 and an Enermax 460. Bargain bin huh?
doc2345
191
Just a quick "chirp in". I won't attempt to defend Tom, but I could/would state that from personal experience that the Antec PS's are crap..... I've never had a product with a higher failure rate nor have I had to deal with worse tech support! I believe the product is trash!
Zap
22,377
7
Never dealt with their tech support. Have only owned their TruePower line and all worked as advertised. A friend of mine has a TruePower and it works very well. The company he works for utilized a bunch of Antec Phantom units (the 300-ish watt passive one) and every one of them is dying. Why? My theory is that they are passive, the systems are P4 Prescott and they are being run in outdoor conditions in SoCal. So far they have all been dying over this past summer. No great suprise. Is it Antec's fault? Not sure since I've never used a Phantom, but I do know it was the wrong choice of PSU[/u] to run a passive power supply for a P4 Prescott in SoCal summer outdoors.
I can hardly call the SPCR reviews unbiased. I do think they do a great job, but their conclusion is definately biased. Why do I say this? Because the best PSU in the world will get a bad review from them if it is noisy. :p Otherwise, I do like their reviews.
Its not incombent upon me to prove that Tom does not take kickbacks etc...
But it is incumbent upon the people who say he does to back up there words!
Yes, I would like to see proof. Now, I do realize that taking advertising dollars can create undue skew on a review, but that doesn't mean such-and-such company is actually going, "Hey Tom, I'll write you a $3000 check right now if you, ahem, you know, with the upcoming PSU review." Some sites may be swayed more than others from advertising dollars, but it should be safe to say that any site taking in serious advertising dollars may be swayed in their choice of wording for a review. This means Tom's. This means Anandtech. The outcome may be the same, but wording will change. For instance, "this PSU blows goat balls and I wouldn't use it to power an eMachine" is a bit different than "this PSU is suitable for the typical consumer system but may disappoint the avid enthusiast." I'm using a made-up statement to demonstrate that a negative review can be emasculated to provide a pseudo-endorsement. I think anyone writing a review for a publication that gains income from advertisements are guilty of this to some degree. That degree can be a lot (as many suspect Tom's) or a tiny fraction of a fraction, but that sway is still there. In addition, we should all suspect reviews of provided products as well, because if a site absolutely depends on review samples provided by manufacturers (and to a much lesser degree, from vendors) then they cannot afford to piss off the source of thier review material.
An organization such as Consumer Reviews would be ideal, except computer industry moves too fast for such reviews to be timely. I do not have an encompassing solution for this, though one drop-in-the-bucket would be peer reviews from people who purchased review units from their own pockets. However, that has the danger of people thinking more highly of what they've spent money on than they otherwise would. Still, I'm thinking of doing this on my own web site. Remember, you heard it here first... well, second. Karaktu was first in a PM.
Originally posted by: biostud
Don't confuse the article with a PSU review article, it only tests wether they can deal with the maximum load for a periode of time. Basically if the label on the side matches to "real world" performance.
This is a great observation. Indeed this observation immediately gives value to the Tom's article. Why? Well, isn't it good that some site looks at a manufacturer's claim and validates or invalidates them? For instance, I recall reading in some article that any water sold as "spring water" in the state of California has to pass a simple test to allow for it to be sold with that explicit statement. The state of California will ask the water bottler, "where's your spring?" Basically water cannot be represented as "spring water" and sold in California if it doesn't come from a spring.
What if there was something similar to prevent power supply companies from overstating their wattage rating? Wouldn't that be great? Right now we have companies mostly adding together power output from various voltages to get their total regardless of whether that total can be achieved when all voltages are used simultaneously.
What the Tom's article is doing is saying, "your label states these numbers, our results show same/different numbers." Nothing wrong with that.
Tom's may screw up stress tests but their methodology in their power supply tests is way above the usuall "testimonial" type reviews
I'm not intereste in fan boys "I have one and it works just fine" comments. These systems are not really stressed.
Tom's tersts do not show...
Tom's tests do not show...
More great observations. Let me invent a PSU review that may sound familiar to many...
Zap's Fake PSU Review Brand XXX Model XYZ-550W
This PSU has these numbers on voltage... see how it has enough power for any system?
Here are some pictures...
Here are the voltages that Motherboard Monitor tells me...
This PSU runs my system great. I highly recommend it and give it 8/10 stars!!!
Sure, Tom's review/tests isn't the end-all to PSU testing, but it is a major step above the majority of "reviews" of PSUs I've seen, and thus it does have value.
... as long as none of the results are invented, as some imply. I do not know how to prove one way or another.
From what i remember Tom himself is very very smart, however, the people who do his reviewing are morons.
I agree with this statement. Tom Pabst is at minimum somewhat academically intelligent since he has a PhD. He has at minimum some business sense since he's making about five trillion times more money off his web site than most of us make off our own. I personally would say just these two facts (yes, I'm 99.99999% sure these are facts, as computed by my Pentium 90) would be enough to mark him as "very very smart" in my mind.
His reviewers are a mixed bag.
I don't know enough about the CPU stress test, though if indeed numbers were changed and covered up then the whole article should be invalidated.
I do know that I was very put off by a recent article titled Up And Down With Antec's P180 Case. Reading that was... a waste of time for expecting a review... almost made up with by entertainment value for laughing at the 'tard who wrote it.
What do people think of Tom's Networking? IIRC he "acquired" a networking review site and added it under his umbrella. I have found the Tom's Networking reviews/articles to be of interest to myself. Indeed the author of that section seems to have a consistent "review recipe" and seems to make attempts at providing good information.
EDITED: Accidentally forgot to close a bold tag.
maluckey
2,933
wyrmrider
I happen to agree on the part of rated temps at max output. I dare say that most of the PSU's would fail afterr a few hours. Even the well respected FSP/Sparkle ATX GES and/or EPS +12v models would be seriously straining at 50 C. for extended periods. They ARE rated at 50 C. though, unlike a certain manufacturer that rates at 40 C. for their middle line, and only 45 C. for their upper line. FSP rates theirs at max load and temps for their better lines. Blue Storm is NOT their better line......
Most people also do not seem to care what happens to their system when a PSU lets go, but I can assure everyone that when it happens, it's generally ugly and expensive. I lost 2 HDD and a 2 vid-cards to a series of failures under the same manufacturer. The manufacturer replaced the units (all three), but I no longer have any faith in their products, and stick to Sparkle ATX GES/EPS +12v for the moment.
BTW,
FSP makes: most Verax, most Conrad, many Zalman, most all AOpen, FSP, Fortron, SPI, Powertech, some of the older powerMAN, Sparkle
Ripple, and mobo protection rules the roost at maximum abuse levels. I really don't care what they can do when cooled to rediculously low temps (40 C) that never are not likely to occur in an OC'ed/air cooled setup. After all, Air-Conditioning the room just to keep case temps low for PSU purposes isn't a good option. It's cheaper to buy a better unit.
rise
9,116
46
jeesh, its Toms :roll:
the antec eventually passed when antec showed up to either-
1) show them how to run the test properly
2) brought enough cash.
take your pick :p
