Single monitor performance doesn't translate to multi monitor directly does it? I heard there can be scaling issues that disappear when you run single monitor.
I love to see these type of benchmarks, but they are really not useful for the majority of people.
Even people who could spend the money on that monitor setup choose not to. I know one of those people very well.
Someone has already posted in another thread: it's driver issues. NVIDIA is having a problem with SLI performance at 4k, has acknowledged it and is working on a fix. It has nothing to do with VRAM. It's also largely pointless because no one is gaming in 4k and no content has been created to natively run in 4k.
But that can also be said for anything, not everyone that has the money to burn will go all out but some will. The richer people in some cases are the most price conscious.
Except look how deep the niche already is with these cards, without even getting to the resolutions:
- People who buy discreet cards
- People who buy discreet cards that are $500+
- People who buy discreet cards that are $500+ and use those resolutions
I am not discouraging publishing the info, I am just saying that it isn't very applicable to how the card performs for the majority of the niche market that buys it. Although at this point one could say that buying 2X 290x or 780ti cards to run @ 1080p means you don't read reviews at all![]()
Except now the CF issues are basically solved and the performance is higher.
I don't see a single downside to a 290/x CF setup...even for the games that don't multi-card.
Still no DX9 frame pacing support even on the 290 cards. Probably not an issue for most but makes me glad I went SLI as I am replaying The Witcher 2 right now and running with Ubersampling is incredibly demanding still.
Again, all you people need to chill out. This isn't an argument over the 290x switch. They tested and listed both. I don't really see there being an issue there. I do think in a case such as this that they do NEED to list both and they did.
The real issue seems to stem from some confusion over Nvidias numbers. It was not made clear that they are having problems and it made the AMD cards look unusually good. Now that I (and everybody else in this thread) know that Nvidia may fix the issue and perform better eventually there's nothing to fight about.
Fact: Right now CF with the new 290/x looks better than the 780ti SLI numbers (at least in "4k"). That may change in the future.
What I think is interesting and I'd like to steer this thread towards is the great performance/scaling of the 290/x regardless of any issues Nvidia may or may not have.
We don't have exact numbers for vanilla 290 CF but I posted a theoretical comparison in my first post. If the 290 is 5% slower than the 290x non Uber then I can use those CF numbers and approximate. With most of the major CF issues fixed, and the high speed of a single 290 there doesn't seem to be a major downside to going 290 CF over a single 780ti and you can potentially get very large performance gains.
What's different though is that Nvidia's problems are driver level and, as of right now, there is absolutely no solution to fix it.
You are insulting buyers of the high end cards.
If somebody knows how to check FPS it's most likely that person would know where is the switch.
I don't know what to say about that.
It is an issue, and apparently what caused me to make this thread.
Probably should have been discussed/made clear in the review.
Multi-GPU is about software, not hardware. 780ti is clearly the fastest single GPU on the planet, and SLI profiles will catch up.
Traditionally, SLI seems to scale up a bit worst than Crossfire. Therefore, it's no surprise a 290x Crossfire is faster than a gtx 780 ti SLI eventhough a single GTX 780 TI is a bit faster than the 290x.
All the reviews I am seeing show the 290x Xfire only overtaking 780ti at 3XXX resolution....
As with almost all new card releases, SLI and CF performance is *usually* lacking out of the box. It improves with new driver releases. Only this time AMD did their homework and seems to have got it right from the beginning. Nvidia will almost certainly catch up in the weeks ahead to fix this. Meanwhile, the 99% of users who do not have 4k resolutions will not lose any sleep over it.
Just as 99% of gamers who aren't going to be buying 2x $700 GPUs... no need to worry about it...
