why do we still use phillips screws?
Numenorean
4,442
Philips head are specifically designed so you can't over torque them, that's why. The screwdriver slipping out is the design working properly.
If they were designed this way then you couldn't actually over-torque them in and then be unable to get them out.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I think you need to read Lemon Law's post. A little rust, corrosion, etc., and the amount of torque needed to remove them can easily exceed the intended amount of torque to install them.
Drako
10,697
161
I don't think people understand when the Phillips head was invented, and what the tools were like back in the day. If I'm out in the field, and a need a basic screw head, I will take the Phillips head because normal people don;t carry torque wrenches with them :D
Sea Moose
6,933
7
I use a "Number 2" size philips bit in my cordless drill. I find that it covers 80% of requirements.
The other 20% i keep a screwdriver that has various sizes.
Using the right size makes a huge difference.
I also keep a small cordless drill that is an impact driver. Very handy for overtightened brass fittings or stainless steel screws that strip fucking faster than a girl in vegas
Alone
7,490
I prefer hex/allen bits. I don't need a screw to tell me how much torque I need.
