Originally posted by: gsethi
Discuss.
I would, but I think using the proper terminology would really help.
When you refer to "flathead" screws, are you really meaning to say slotted screws? The two are completely different as there are flathead screws that are screwed in by philips screwdrivers and flathead screws that are screwed in by slot-type, or flat BLADE, screwdrivers.
Here are some definitions of types of screws:
Head Shape
* Pan Head: Standard screw head profile with average diameter and average height.
* Button Head: Similar to a pan head but with a curved top.
* Round Head: More pronounced head than a button head.
* Flat Head: Flat top with a tapered underside that is intended to be driven into a countersunk hole.
* Oval Head: Tapered underside like a flat-head, but with an oval top.
* Truss Head: These are large-diameter heads with a low profile.
* Fillister Head: Thick profile with a slightly rounded top.
Driving Methods
* Slotted: Slotted screw heads are perhaps the oldest and most common variety; a linear slot in the head accepts a standard (flat) screwdriver.
* Phillips: The phillips head is an improvement to the slotted screw; cross-shaped grooves accept a phillips-head screwdriver. These heads provide a larger mating surface between the screw and the screwdriver which minimizes wear and helps prevent slipping.
* Hex: These heads do not have any grooves or slots at all; the entire head is hexagonally shaped and they are tightened with a wrench. Since the size of the heads varies, a wrench set or an adjustable wrench is required for driving hex screws.
* Square: (also know as Robertson drive). These heads have a square indentation to minimize slipping; they also require a special driver for tightening and loosening.
* One Way: One-way heads are a variation on the slotted screw. They can be tightened with a standard screwdriver, but are tamper-resistant because they require special tools for removal.
* Torx: Torx heads have 6-pointed recessions to provide even more surface area for driving. They require the less-common torx screwdrivers and therefore can be considered tamper-resistant.
I only bring this up because if you walk into a hardware store and ask for a flathead screw, you are going to get this:
A flathead screw.
It'll be used to do this......countersink.
It'll most likely be a wood screw and be used to countersink into the wood.
It will most likely have a slotted-drive top, but there is no such thing as a flathead screwdriver.....it's a slotted screwdriver.
Just trying to save you some embarrassment from your ignorance of the subject you feel so deeply about.
