Originally posted by: JulesMaximus
It's all in perception. I love the sound of a turbocharged 2.5l boxer 4. 😀
Originally posted by: Ornery
Even a six can sound good. It's the size of the jugs!
I've heard some pretty nice burblage from WRX's....Originally posted by: DivideBYZero
There is a four that 'burbles'...
A little burbley...Originally posted by: dug777
i'm waiting for Insane3D to shout me a recording of his V8 🙂
my cat purrs louder than those POS!
when a car cams so hard that it sets car alarms off 3 doors down at idle.... thats bluurbage...
Originally posted by: aircooled
it's in the cam...
I tend to call major cammage a "lopey" idle.
Not the same as general burble.
😀Originally posted by: iamwiz82
You know you over did the cam when the headlights dim and brighten at idle. 😛
Originally posted by: NutBucket
Originally posted by: Howard
Ferrari still uses flat crankshafts.Originally posted by: GalvanizedYankee
Number of cylinders, firing order, exhaust configuration...
Howard is real close. Firing order on most, 1-8-4-3-6-5-7-2, it can be seen that one side is allways out of synk with the other. That is that the firing order will fire two cyls on oneside than the other side will do like wise. All V8 cranksshafts have rod journal placement at 90 degrees. Back in the olden days 1960 something, flat cranks were tried inorder to increase HP. The rod throw journals were at 180 degrees to eachother this made the motor run as if it were two 4 bangers. One bank would fire than the otherside. This made exhust pipe tuning much easyer and intake manifold runner tuning easyer. But no real power gains were realized. They just sounded extra bitchen. Like two Offenhousers racing side by side.
Flat cranks are a thing of the distant past. But with these motors no cross or balance pipe was needed as is used in all NASCAR engines today. The X-pipe is a must to balance out the uneven firing side to side.
I hope someone understands that cause I don't.........😉
That's what I was going to say. I believe the V8 used by Lotus in the final Esprit was a flat-crank as well. Those suckers just SCREAM😀
Originally posted by: gigapet
mine is virtually silent at idle and full throttle
You know you have to start the engine, right? 😀
