Why do they cut lines in concrete?
shortylickens
80,287
17,081
Separate slabs allow the earth to move underneath without actually cracking the concrete. But if you're talking about what I think you're talking about, they do it cuz it looks cool. Which is annoying.
13,804
Come to think of it, why is it that basement slabs normally don't have these? Is it because they are poured so thick that they're not needed?
mmntech
17,501
12
The sidewalk outside my building was recently redone by the city. They poured like a 50-foot long slab and then they cut "lines" in it to make it look like individual 5-foot sections. The lines don't go all the way through; they are only about 1/4" deep.
Why do they do that? Just for aesthetic reasons? Sounds like a waste of manpower to me. What's wrong with a 50-foot slab of concrete that looks like a 50-foot slab of concrete? Confusing concrete construction is confusing.
Expansion joints. Gives the slabs room to move as it heats up and cools down through the seasons. Otherwise they'll heave and crack. Most concrete structures have these cut into them. That's what the metal lines on bridges are.
lxskllr
60,044
10,533
Probably due to depth. A basement slab should be below the frost line.
wirednuts
7,121
4
yup. its also because you want a flat floor for indoor use. and if you notice, basement floors crack in crazy ways, and its not nice looking. but again, you want a flat floor so you just let it crack and the patch it. if it even makes a difference. if you have carpet, let it crack and you will never see it.
vi edit
62,484
8,345
Part of it is because the basement doesn't have as much temperature fluctuation as a driveway or sidewalk exposed to all sorts of elements. Another reason is because many basements get covered up with carpet and nobody cares. Another reason is because the contractor was lazy and the owner/CG didn't care. And another reason yet is because a basement slab will normally contract away from the foundation walls as it cures and then expand a bit as it goes through temp changes. But nothing to the extent of an unprotected/insulated slab.
crashtestdummy
2,893
This. The lines more than just separate the slabs (though they do also keep cracks from propagating between segments). They are designed to provide some space so that cracks from thermal expansion and frost heaves don't occur in the first place.
vi edit
62,484
8,345
Concrete is going to crack, it's just the nature of the beast. You can mitigate it somewhat with rebar, slow cures, act but it still wants to crack with wild temperature swings. Control joints help you to tell it where to crack.
zinfamous
111,858
31,346
so that you have something to jump over, thus preventing your mother from breaking her back.
duh.
Miramonti
28,653
100
The joints are created so that when the cement contracts, it will hopefully do so at these places in order to be more effective at tripping up annoying skateboarders.
XZeroII
12,572
The expansion cracks are not used for drainage. In fact, you want to make sure that you don't get water in them by filling them with an expandable material. The reason is because in the winter, when the water freezes it will expand and push the concrete up and cause big bumps. This also increases the stress and can cause it to crack as well. Never underestimate the power of freezing water.
MichaelD
31,528
I must admit that there were a lot of educational replies to my question. Thanks guys! I learned something today.
Humpy
4,464
596
There were a lot of replies but most of them are wrong. :)
People are confusing/combining the control joint, and its function, with the expansion joint.
OverVolt
14,278
89
I figure sidewalks used to be individual slabs of concrete and then to cut corners they did the 50 foot slab pretending to be individual slabs deal and it just stuck. I've seen tons of sidewalks cracked right down the middle I don't think it matters lol.
