Why do my 3dmark scores suck on my OCed system?
Renob
7,596
I have a NF7-S v.2
mobil 2600 @ 11.5x200 2300mhz
ATI 9800 pro @ gpu 405 mem 357.75
corsair platinum xps pc 3500 ddr 433
Im using the Omega drivers. and even if i go back to the ati drives my scores are still low.
I have nothing running in the background.
When I built the sytsem it would score and this was with a non overclock on the vid card and stock drivers
3dmarks 2003 5700
3dmarks 2001 16,300
Now with the overclocked vid card I get
3dmarks 2003 5200
3dmarks 2001 15,900
furie27
684
I had a similar when I overclocked my 2600+ too high. The FSB was too high for the memory forcing a 5:4 ratio. Check it using CPUZ and adjust the memory settings in your bios accordingly.
Shimmishim
7,504
open up task manager and check to see if you have anything running...
you may have a virus tha'ts eating up clock cycles...
i think 16k is about right for that system...
DAPUNISHER
31,874
32,035
The 2k1 score is close enough for goverment work and the lower '03 score is most likely due to 4x AF being turned on.
Renob
7,596
System is clean, no virus.
also 4xaf is off.
I have gone back to try the old drivers and set the vid card to normal speed and still no luck.
It giving me no love.:(
Zebo
39,398
19
You must have changed something in the bios or it's not config properly.. Heres a good starting point
Softmenu III Setup
CPU Operating Speed: User Define
External Clock: 200
Multiplifier Factor: 12
AGP Frequency: 66
CPU FSB/DRAM Ratio: 6/6 or 5/5
CPU Interface: Enabled
Power Supply Controller: User Define
CPU Core Voltage: 1.70 - 1.775 to be safe
DDR SDRAM Voltage: 2.7
Chipset Voltage: 1.7
AGP Voltage: Default
Advanced Chipset Features
Memory Timings: Expert
Row Active... : 11
Ras to Cas... : 3
RAS Precharge... : 3
CAS Latency... : 2
System Bios Cacheable: Disable
Video Ram Cacheable: Disable
CPU Thermal Throttling: Disable
Enhance PCI: Enable
CPU Disconnect: Disable
AGP Transfer: 8x
AGP Fast Writes: Enable.
Disable everything with a % sign
If you don't use IR, then disable it.
If you don't use SATA, then disable it.
If you don't use the Parallel Port, then disable it.
If you dont use MIDI, then disable it.
If you dont use the embedded LAN card, then disable it.
If you don't use the embedded Audio, then disable it.
DAPUNISHER
31,874
32,035
How did you turn off AF? On the Omegas 2.5.30's I use it's either app. preference or a minimum of 2xAF and the free version of '03 doesn't let me turn off the 4x AF it uses.
Renob
7,596
Zebo thanks for all the info on the Bios, I will check it now.
But I have a question why would I want to turn up my voltage to my cpu and chipset?
xeno2060
1,518
4
Try the voltage increase just for Sh!ts and grinns and see what happens...you never know.;)
DAPUNISHER
31,874
32,035
If it's stable as is then definitely do not increase voltage unless you want unnecessary heat. BTW, how did you disable AF in '03 with the Omegas? Do I just have the wrong ones or what?
Zebo
39,398
19
Chipset 1.7 is a given for stabilty I've found on the both NFS-7 I have. 1.6 is fine too though..Either way it only helps and can't hurt. And I was going to post a little more, after your results come back, about upping the FSB and tighting the timmings with the killer ram you bought so it should stay there. But for now, I'd just like to see what you scores are under these conditions so you can disregaurd that if you choose.
As far as Vcore, you have a 2600M mildly overclocked, and were complaining about your scores, just suggesting you overclock a bit more and more Vcore may be nessesary?
RussianSensation
19,458
765
Sometimes when the GPU/Memory speeds gets too hot it slows itself down in benchmarking so test at 390/345 see if the score increases
do the same for the CPU to see at which point teh scores keeps decreasing
If your score decreases at any cpu overclocking or gpu overclocking speed isolate each component and keep the other one stock until you find what is causing this.
so reset cpu to stock and gpu to stock
first overclock the cpu and your 3dmark01 should increase until the maximum you can reach with the cpu
now do the same with the gpu while keeping the cpu stock
maybe you'll find a thermal limit for a component.
Renob
7,596
Ok I changed all the setting and here are the scores.
3dmarks 2001 15752
3dmarks 2003 4950
They went down??
This is very strange .
Im not sure were the setting is for turning off the af but Im sure it off. maybe??
mato7742
230
try ventillating the card a little bit if you feel it's heat related. i don't know if you did this yet, but before you posted those scores did you reset your cpu/gpu back to stock?
Renob
7,596
Ok I removed the omega drivers and ran the test with the ati drivers and a normal clocked vid card and now my score for 3dmarks 2001 droped to
14800
Is there a driver cleaner out there that will clean out my system I have loaded drivers on it about 10 times for the vid card I think that might be part of the problem.
Jgtdragon
3,816
19
Seems like the more you tinker with it, the more its going down.
You running Windows XP? Run system restore back to the date you have the highest score to see its a software problem.
Renob
7,596
Ok I just ran a driver cleaner and reinstalled the omega drivers and got a
16552 yahoo! my best score ever and at only 2300mhz on the CPU.
And 5817 for 3dmarks 2003
Thanks guys for all your input.
Sokratz
193
Softmenu III Setup
External Clock: 200
AGP Frequency: 66
Row Active... : 11
Ras to Cas... : 3
CAS Latency... : 2
Enhance PCI: Enable
AGP Transfer: 8x
I was under the impression that enhance pci should be disabled for max oc stability?
Renob
7,596
Could you please give a little more info then just
should we hitting 19000
Somniferum
353
This sounds like a problem I had at one time. Make sure AA/AF are not being enabled somewhere else. Depending on what apps you have running, it may be turned on without you realizing it. I had AA/AF disabled in the drivers, but Powerstrip was overriding the driver settings and turning these functions on anyway. Result was 3dMark03 scores similar to yours. Make sure whatever vid-card-related apps you are running are not conflicting with one another.
Optimummind
86
I don't think AMD CPU's have the thermal control circuit found in Intel Pentium 4's to increase the number of null cycles to bring the temp of the CPU down. It only applies to P4 CPU's.
Also, his GPU doesn't have the thermal monitor that downclocks the GPU automatically.
RussianSensation
19,458
765
Yeah you r right so it's definately not the cpu but GPUs have a tedency to overheat and they actually do slow down at very high settings like my 8500 does worse when i overclock it to 310/310 than at 300/300 so that is the only explanation i can provide. I can't think of anything else. The reason why i told him to test both parts is to be able to isolate them for sure; that way he will find the problem sooner.
