brblx
Originally posted by: Eli
Originally posted by: Skoorb
Maybe I should have said "little" to do with it? 🙂 The closest I've ever come to tearing apart an engine is taking off an intake manifold! However, if friction was really appreciable enough to literally steal multiple MPG for the work done I believe that heat and wear would transfer quickly into failing parts and bad tolerances. A well lubricated engine surely should feel extremely free in its motion.
You are correct, friction has very little to do with an engine's efficiency. Sure, an 8 cylinder engine has more drag than a 4 cylinder, that is a given.. but it is more or less negligible for purposes of this discussion. I'm not even sure if "friction" is the right term, it's more due to oil viscosity drag.
friction would be the right term, but the amount of friction in a broken in engine is very low. nothing compared to fighting compression- a used engine with the heads off is usually loose enough to keep going for a sec if you spin the crank by hand.
the important thing that the OP should realize is that horsepower and gas mileage are really not related. they may seem so, but the maximum amount of power an engine makes (at whatever arbitrary rpm) really has no direct correlation to gas mileage. it's not like if a 100hp engine gets 40mpg, you can deduce that a 400hp one gets 10mpg. just doesn't work that way, there are too many other things in play.
as i believe someone else pointed out, a big engine won't always cause a mileage drop. if the engine is able to make it's power at much lower rpm (and can cruise at that rpm) without being under too much duress, it may actually get similar highway mileage to a smaller motor. the fourth gen camaros/firebirds are a good example of that, you could get high 20's or better in the models with a somewhat ridiculous .5:1 top gear.
remember that there are two things that effect the amount of gas an engine is using- rpm and load. skoorb gave the example of a car in first gear at 25mph vs fifth. this really assumes that the amount of fuel going into an engine is only related to how fast it's spinning, which just isn't true. you could actually get worse mileage in that situation (maybe- 25mph in 1st would have the engine screaming in most cars). in a more realistic scenario, say 30mph in either 3rd or 5th, 3rd very well might afford better mileage. you have a greater mechanical advantage over the back wheels, which means that the engine doesn't have to work as hard.
