Java is a major PITA. I keep a couple batch files that renames all the JAVA executables whenever i'm not using it or renames them back when I need to use it. I have to use java for work otherwise I'd uninstall that big gaping security hole.
thats a good idea. i got a virus last year from java. i was just entering a website then java icon comes up in system tray and whole comp went haywire and started installing things. havent installed java since but miss it for a couple things. which exes do you rename and will it stop anything from running java?
batch file to "Disable" java
ren "C:\Program Files (x86)\Java\jre6\bin\java.exe" java.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\javaw.exe" javaw.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\javacpl.exe" javacpl.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\java-rmi.exe" java-rmi.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\jbroker.exe" jbroker.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\javaws.exe" javaws.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\keytool.exe" keytool.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\rmid.exe" rmid.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\jp2launcher.exe" jp2launcher.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\jqs.exe" jqs.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\jqsnotify.exe" jqsnotify.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\kinit.exe" kinit.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\klist.exe" klist.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\ktab.exe" ktab.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\orbd.exe" orbd.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\pack200.exe" pack200.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\policytool.exe" policytool.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\rmiregistry.exe" rmiregistry.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\servertool.exe" servertool.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\ssvagent.exe" ssvagent.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\tnameserv.exe" tnameserv.ex_
ren "C:\Program Files (x86)\Java\jre6\bin\unpack200.exe" unpack200.ex_
pause
Batch file to "re-enable" Java
ren "C:\Program Files (x86)\Java\jre6\bin\java.ex_" java.exe
ren "C:\Program Files (x86)\Java\jre6\bin\javaw.ex_" javaw.exe
ren "C:\Program Files (x86)\Java\jre6\bin\javacpl.ex_" javacpl.exe
ren "C:\Program Files (x86)\Java\jre6\bin\java-rmi.ex_" java-rmi.exe
ren "C:\Program Files (x86)\Java\jre6\bin\jbroker.ex_" jbroker.exe
ren "C:\Program Files (x86)\Java\jre6\bin\javaws.ex_" javaws.exe
ren "C:\Program Files (x86)\Java\jre6\bin\keytool.ex_" keytool.exe
ren "C:\Program Files (x86)\Java\jre6\bin\rmid.ex_" rmid.exe
ren "C:\Program Files (x86)\Java\jre6\bin\jp2launcher.ex_" jp2launcher.exe
ren "C:\Program Files (x86)\Java\jre6\bin\jqs.ex_" jqs.exe
ren "C:\Program Files (x86)\Java\jre6\bin\jqsnotify.ex_" jqsnotify.exe
ren "C:\Program Files (x86)\Java\jre6\bin\kinit.ex_" kinit.exe
ren "C:\Program Files (x86)\Java\jre6\bin\klist.ex_" klist.exe
ren "C:\Program Files (x86)\Java\jre6\bin\ktab.ex_" ktab.exe
ren "C:\Program Files (x86)\Java\jre6\bin\orbd.ex_" orbd.exe
ren "C:\Program Files (x86)\Java\jre6\bin\pack200.ex_" pack200.exe
ren "C:\Program Files (x86)\Java\jre6\bin\policytool.ex_" policytool.exe
ren "C:\Program Files (x86)\Java\jre6\bin\rmiregistry.ex_" rmiregistry.exe
ren "C:\Program Files (x86)\Java\jre6\bin\servertool.ex_" servertool.exe
ren "C:\Program Files (x86)\Java\jre6\bin\ssvagent.ex_" ssvagent.exe
ren "C:\Program Files (x86)\Java\jre6\bin\tnameserv.ex_" tnameserv.exe
ren "C:\Program Files (x86)\Java\jre6\bin\unpack200.ex_" unpack200.exe
pause
I don't get it. In what situation does this protect you?
With google chrome, I have "block all" enabled for all plugins - includes Java applets. For a small number of specific websites that I go to regularly (e.g. youtube) I have Adobe flash enabled. If I want to run a blocked plugin on a particular website, I can right click and select "allow plugin" - real easy. I haven't needed Java anywhere so far.
