Don't be dumb and buy an expensive soldering iron unless you plan to spend a ton of time soldering. With my $5.99 15W soldering iron from Radio Shack, I've soldered two different 29-wire modchips on Playstation 2s, soldered quite a few Playsation 1s, audio out pins on a SB Live value, and I've even done soldering for plumbing (though, that uses a blowtorch).
BUT.. USE FLUX. People that don't 'use flux' are either soldering wrong or using flux without even knowing it. (There is usually a small amount of flux left on soldering locations or in the soldering wire itself.) The flux is the adhesive. Think of it like primer..
You can tell you've soldered correctly when where you've soldered looks just like the existing soldered items on a board. Anything you solder should be fairly strong - will hold up if you bend the wire.
1. Apply flux to end A and end B (assuming you're soldering A to B)
2. Melt a small amount (not a big ball) of solder to the end of the soldering iron
3. Brush soldering iron on end A and end B. Make sure the wires are heated - so give it some time. Dropping a bunch of solder on cold metal does nothing. The flux should sizzle and smoke.
4. Put A to B and touch with iron. Again, the flux should sizzle and smoke. When it does, quickly remove the tip of the iron.
5. Tug lightly on the connection to test its' strength.
