Anubis
yes everyone knows that thats just what they are sold as. does nakamichi make anything anymore? for some reason i wanna say they are dead
i own a RX 505 BTW
i own a RX 505 BTW
i own a RX 505 BTW
Man, what are you on? This kind of stuff doesn't even matter.Banana plugs are more convenient, and achieve greater contact area, yes.
However, most banana plugs are gold plated, and you may know, gold's electrical resistivity is 30% greater than copper, which means in reality, power delivery is not an advantage versus spring clips.
Of course, you could use copper plated banana plugs, but those will rust just as fast as copper wire.
The only way to achieve the power transfer of copper with the oxidation properties of gold would be to forge two plates of metal together. These plugs exist, but are obviously extremely expense. Not too many people would dish out $50+ for a single banana plug.
Besides, if you were to measure the contact resistance of a gold-plated banana plug in a binding post and the resistance of bare wire in a spring terminal, the banana plug will have way way less. If you don't know why, do a little research on electrical resistivity.
if you do short it out by contacting the cables, do you blow the amp or a fuse?
wowGood one Howard. I would ask you to back up your claims, but every time I do, you disappear. You are the king of hit and run--dismiss someone's post, and then vanish when someone asks for you to substantiate your claim.
I nominate you for "King of Trolls."
What you are saying here is that gold-plated plugs suffer in terms of voltage drop and/or maximum power capacity compared to bare wires in spring terminal connections.However, most banana plugs are gold plated, and you may know, gold's electrical resistivity is 30% greater than copper, which means in reality, power delivery is not an advantage versus spring clips.
You are trading an advantage for a deficiency here.Of course, you could use copper plated banana plugs, but those will rust just as fast as copper wire.
A proper solder joint or even a crimp connection has no problems transferring large amounts of current (relative to a wire gauge), and neither have problems with oxidation. Also, I'm pretty sure a connection which has been "forged" together wouldn't be ordinarily separable in the first place.The only way to achieve the power transfer of copper with the oxidation properties of gold would be to forge two plates of metal together. These plugs exist, but are obviously extremely expense. Not too many people would dish out $50+ for a single banana plug.
