Question Why are SOHO routers adding advanced features like Wifi Guest Networks, Wired VLAN, and even Dual-WAN, but no "Wired Guest Network"?
VirtualLarry
56,552
10,171
Like dual-WAN, it would use VLAN support of the wired switch chip, to create one or more ports of an "Isolated VLAN", that couldn't access your LAN resources (like a NAS), but could only access the WAN. Possibly, it would have it's own WIRED GUEST DHCP/IP subnet too.
Basically, the wired equivalent of a Guest WIFI w/client isolation. Not quite the same as a true DMZ port, as it would still utilize NAT and SPI.
This would be a godsend to those of us working on relative's PCs, that might have viruses on them that could spread over the network.
Edit: They could also promote that setting as for "Smart TVs", such that, if hacked, couldn't be used as a staging platform to attack the rest of your network. Of course, by the same token, playing videos off of the NAS would also be off-limits to a Smart TV plugged into "Guest WIRED port".
ch33zw1z
38,201
18,670
Really tho, if PC work is your thing, having a VLAN'd network is the way to go. Ditch the consumer junk and get something you can isolate traffic with.
I use Ubiquiti, ER-X and a LR WAP, found a guide that helped overall:
I modified parameters to fit my config, and created a isolated guest wifi and an IoT wifi (for Nest devices).
Before I configured the firewall rules, I confirmed with ping that traffic could flow between VLAN's.
After I set firewall rules, the isolated networks can't do anything but access internet.
All I would need to do is set a port to the same isolated vlan VID to make it work the same way now.
MtnMan
8,960
8,191
It needs to be on every router, at least those that offer guest WiFi.
Best practice is to run all of your IoT devices on the guest network separate from your main network, and since many are WiFi devices, easy enough. However some connect via Ethernet, so I've got about 8 - 9 devices on the guestwifi, but one for security cameras on the main network.
Just allow a single LAN switchport to be assigned to the same VLAN/subnet as the guestwifi.
  • Love
Reactions: VirtualLarry
ch33zw1z
38,201
18,670
It goes back to post #2 in the thread. Market segment. If / when a big SOHO maker makes this an option, it won't be across the board. It will be a feature on a router that's premium and priced as such.
VirtualLarry
56,552
10,171
I'm really hopeful, that with modern router chipsets and switch chips, that almost certainly support VLANs, that Router mfgs would make it a "standard feature", such as "Wireless AND Wired Guest LANs", just like they did with "Simultaneous Dual-Band". (*Remember, it wasn't always simultaneous, and always-on on both bands. Those were the "bad old days", and IMHO, these days are the "bad old days" with Guest Networks, with so many IOT things popping up, that should be segregated, whether wired or wireless, onto a VLAN that can "only" access internet.)
ch33zw1z
38,201
18,670
It's possible, I just don't see SOHO manufacturers doing this on all their devices anytime soon
MtnMan
8,960
8,191
But on their higher end devices there is no reason to not offer this function.
I wouldn't even expect them to have the feature on low end/entry level devices.
ch33zw1z
38,201
18,670
I can see your point, it may or may not happen as a SOHO level. There's other vendors out there who provide low cost solutions, I wouldn't mind seeing one from Linksys or Netgear, but not gonna get my hopes up.
