- Aug 25, 2001
- 56,585
- 10,225
- 126
Like dual-WAN, it would use VLAN support of the wired switch chip, to create one or more ports of an "Isolated VLAN", that couldn't access your LAN resources (like a NAS), but could only access the WAN. Possibly, it would have it's own WIRED GUEST DHCP/IP subnet too.
Basically, the wired equivalent of a Guest WIFI w/client isolation. Not quite the same as a true DMZ port, as it would still utilize NAT and SPI.
This would be a godsend to those of us working on relative's PCs, that might have viruses on them that could spread over the network.
Edit: They could also promote that setting as for "Smart TVs", such that, if hacked, couldn't be used as a staging platform to attack the rest of your network. Of course, by the same token, playing videos off of the NAS would also be off-limits to a Smart TV plugged into "Guest WIRED port".
