dullard
Insulation + proper ventillation should result in not much difference at all.With insulation I doubt it matters how much heat your roof is absorbing.
Of course, if you skimp on either, then you might see a difference. But the solution isn't changing the color of the roof in that case, the solution is to fix your poor insulation/ventillation.
And, there is the other part of the picture. Even in Dallas (and many other parts of Texas) half of the year has daily temperature highs below 70°F where you WANT to absorb the sun's heat.
