- Oct 30, 1999
- 11,815
- 104
- 106
Originally posted by: Howard
Certain limitations can happen. I believe I came across one such issue when researching the Enhance ENP-5140GH (model # off the top of my head), 12V1 was limited to 16A and 12V2 was limited to 18A, with 32A total. IIRC, 12V2 was for CPU and 12V1 was for mobo/graphics.
Let's see if I care enough to check that now...
EDIT: I was right about everything about maybe CPU - the full 8-pin connector draws from both 1 and 2, when split, it's probably only 2 that it draws from.
I think Enhance is the only PSU's I've seen with an even split. But usually it's the connector with the lower number that provides power to the CPU and whether it's a 4-pin, 8-pin or a 4+4-pin, typically they draw power from the same rail.
If they're going to follow the ATX12V specification with limits on rails, they're usually going to also follow the part about putting the CPU on it's own rail.
