That's the thing. I'm wondering if I would even notice anything faster than my Phenom II at 3.75ghz.I have an i5 750 that I had clocked to 4GHz. At some point, I had updated my BIOS and forgot to dial in my OC again. I went several months at stock speeds without even realizing it. I think it's going to be a while before I find myself wondering out aloud, "I wonder if it's time for a new CPU?"
Now show me a nice 100-128GB current-generation SSD (SF-2000 series or equivalent) at maybe $1.50 per GB and I'm going to pounce on that. I can dream, can't I?
Same here. The problem is that the new Intel X25-M drives cost exactly the same amount as the previous drives, and they will perform the same or worse in all likelihood.most likely upgrade for me would be getting an SSD.
Zenoth, I would go with something faster than a gtx560. that's only about 30-35% faster than your gtx285.
I was just pointing that out if were expecting a big performance jump.Sure, send me some money and I will.
Yes, and then you can cry to your mommy when the memory overheats, giving you an expensive paperweight that's not covered under warranty. D:The 6950 2GB going for ~$220AR is pretty sick as well, especially since you only need be a pre-school dropout to unlock it![]()
Uhm WTF? Be a little conservative and flash an unlocked BIOS with 6950 speeds and timings, then OC manually using a utility - which is what I did.Yes, and then you can cry to your mommy when the memory overheats, giving you an expensive paperweight that's not covered under warranty. D:
I agree with OP that the itch to upgrade just isn't there for me anymore. I'd rather extend the life of my initial money spent as much as possible..
Over time I guess you find to realize that there's always something new around the corner to look fwd to. If I skipped 2-3 gens that's fine, I'll get in on the next new thing.![]()
