Whos getting Ivy Bridge?
thm1223
336
I intend to build a gaming rig with Ivy Bridge as soon as Nvidia's Kepler is released.
Kristijonas
859
4
And I intend to build a gaming rig with IB integrated graphics! SB integrated graphics is already almost enough for my games.
Ken g6
Moderator
Dec 11, 1999
16,722
4,684
75
I'm gonna get an Ivy Bridge laptop. And see what the onboard GPU can do. Especially in terms of writing GPGPU programs for it. :)
My Celeron M 1.5GHz laptop from 2005 is getting just a little old. ;)
AdamantC
478
I'll probably be grabbing it along with the next gen GPUs. It is about time I retire my trusty S939 Opteron 175.
bunnyfubbles
12,248
With a Microcenter just a few blocks away, and my addiction to hardware, I would have to say it is pretty much a given that I will.
The better question would be whether or not I go SB-E. If Microcenter can slash the 3930K enough I might just jump to the s2011 platform if there are some early X79 motherboards that are worthwhile to bother with.
Kaekae
129
I'm pretty sure I'm going to wait for the benchmarks, then read the reviews, then look at the benchmarks again and them I'm going to get so impatient that I'll have to buy it off of Newegg.com. That's what usually happens. I try to stay patient and say don't ugprade, but after reading everyone's success with an overclock or a decent gaming benchmark at the right time I can't control the urge.......
I also purchased my mobo directly related for an Ivy Bridge CPU upgrade.
notty22
3,375
I also like die shrinks. It will be interesting whats available , that's priced similar to the i5 750, i5 2500k etc.
Ferzerp
6,438
107
It depends on performance. I don't make buying decisions for hardware before benchmarks are available.
Dice144
654
I will long as it is an upgrade over my new 2500k at 4.6. Plus I don't go out much or have any other bad habit cepts for buying computer hardware :thumbsup:
LondonBurning
35
and then 4 months later Ivy Bridge beats it in gaming while having less than half the power consumption and cost.
What makes you say that? Ivy Bridge will only have marginal performance improvement. Most of its perks will be around the power-savings and its much improved on-board video.
Sandy-Bridge-E will have the same PCI-E 3.0, plus more cache/cores and quad-channel memory. How on earth do you figure this will be like the 980X/2600k scenario again?
Those two were based on different platforms where 2600k's improvememtns allowed it to catch up to the aged x58 chips. The x79 stuff is based on the current tech of Sandybridge/Ivy bridge (which is really just a die shrink).
And then once Ivy-Bridge-E comes out the x79 platform will get the same die-shrinked improvement.
Broheim
4,587
Price cuts?
When was the last time Intel had price cuts on a CPU people in these forums would buy? Q6600?
Usually they stay the same price and just go EoL.
http://www.newegg.com/Product/Produc...82E16819115067
maybe $5 cheaper than it was a year ago? Then it was probably called the 750, but 750 never got cheaper, it just got called a 760 and replaced at the same price.
I can't speak for the US, but here in Denmark the 2500K was introduced at around 2000dkk, then it went down to 1500dkk and for a while you could find it for 1200dkk but it's back up to 1500dkk again.
toyota
12,957
um you do realize that Sandy Bridge E is really no faster for gaming than 2600k. even if Ivy Bridge is only 5% faster, that's still faster than Sandy Bridge E will be and will have more overclocking headroom. and again with a 77 watt TDP and thats including the gpu that will not even be used by gamers. go ahead and fork out big bucks for Sandy Bridge E cpu and mobo but for typical gamers, Ivy Bridge is going to make it look silly from a performance, cost and power consumption perspective.
LOL_Wut_Axel
4,310
8
Sandy Bridge-E will probably not get PCIe 3.0 according to recent sources, but Ivy Bridge definitely will. The more cores argument is definitely valid, and at the same clocks the Core i7-3930K would be 30-45% faster in multi-threaded workloads than the i7-2600K and the same speed in single-threaded. You have to pay 80% more for that higher performance, though. Motherboard costs will be higher as well, but you do get twice the number of PCIe 2.0 lanes coupled with a better upgrade path. Quad-Channel memory means nothing for consumers; that's all I'll say. The benefit I see from it is indirect: many motherboards will include a whooping eight Memory slots.
As far as Ivy Bridge vs Sandy Bridge-E, Ivy Bridge isn't "just" a die shrink in the way that going from Conroe to Penryn wasn't. We'll have a smaller process node, but also 5% higher IPC. With it also consumes lower power consumption and higher overclocking capabilities. If Sandy Bridge gets on average 4.5-4.6GHz overclocks, we can expect an average of 4.7-4.8GHz overclocks. That means at voltage suitable for five years at least. If you don't care that much about longevity (as in keeping it running for more than three years) on Sandy Bridge you can extend that to 4.7-4.8GHz, and around 4.9-5.0GHz on Ivy Bridge. What that translates to is around 10% higher performance overall with noticeably lower power consumption, which is not shabby at all. You also have, like I mentioned previously, PCIe 3.0 support, something you probably won't have on Sandy Bridge-E due to Intel either gimping it or not being able to include it for engineering reasons.
Ivy Bridge-E won't be out until Q3 2012 or so, and that's a LONG wait; longer than the gap between SB-E and Ivy Bridge. If the rumors of it supporting eight-core CPUs are correct, though, it'll have amazing longevity provided you can put down $1000 on a CPU. It also means that the six-cores will be lowered in price by then, with one or various models probably at $400-500.
It's all a give or take, but given the lack of features that were supposed to be on SB-E/X79 I wouldn't be too excited about it.
gevorg
5,070
Also, in addition to a bump in IPC performance (5-10% or whatever), Ivy Bridge should increase the average overclock from Sandy Bridge. So for example, if SB could do 4.5GHz on average (with simple cooling), IB will probably do 5.0GHz or higher, which gives an additional 10% boost, for a total of 15-20% over SB. This is just speculation based on the fact that Ivy Bridge raised the the max multiplier from 57 to 63, and the fact that it will be much more efficient than SB.
EDIT: ^^^ LOL_Wut_Axel beat me to it
LondonBurning
35
Well put. I will be waiting for a definitive SB-E review come launch. Signs still point to at least the mobos being PCI-E capable from photos we've seen (even if the CPU doesn't support it, future IB-E upgrade path?)
I think Battlefield 3 will take a big advantage from the 6-cores/12 threads of the 3930K. Also, for those saying SB-E is barely faster, if at all, when compared to the 2600k (like in the Anandtech preview), those tests seemed very GPU limited - so it would be like saying AMD FX is just as good as SB when looking at similarly limited benches.
I'm running a 27" 2560x1440 IPS monitor at home, somehow I think SB-E in combination with an SLI/Crossfire setup will work together nicely when looking ahead to new games coming out.
LOL_Wut_Axel
4,310
8
I'm running a 27" 2560x1440 IPS monitor at home, somehow I think SB-E combination with an SLI/Crossfire setup will work together nicely when looking ahead to new games coming out.
If the most recent sources are correct and we see PCIe 3.0 in Ivy Bridge but not Sandy Bridge-E then it's a better route for gamers because the next-gen GPUs from AMD (Radeon HD 7000) and NVIDIA (GeForce 600) will probably support it. We know there's a very small to no difference (0-3%) at 2560x1600 with 4xAA between PCIe 2.0 x8/x8 and x16/x16, so you may be wondering what the benefit of PCIe 3.0 is. The benefit is that since it has effectively twice the bandwidth as 2.0, PCIe 3.0 x4 is equivalent to PCIe 2.0 x8 and we'd be able to have at last a true Tri-CrossFire/SLI solution. At those resolutions you're also very GPU limited, and unless the title still depends a bit on the CPU by then and supports six cores then it'd be the same speed as having four cores with the same single-threaded performance.
Kevmanw430
279
As long as the GPU is around current A8 GPU performance (~6500 3DMark06), I will get an Ultrabook. I love how they look, especially the ASUS UX21, but I couldn't live with the 3000 GPU. If Ivy's IGP is good, though, then I'm in heaven.
