Whoops! USB Cable into Firewire Port...
Johnny Nuge
36
After months of waiting, I finally scored a P8P67 Pro for my 2600K at Microcenter last weekend. Due to my haste and lack of experience with onboard firewire, I accidentally plugged a USB cable into a Firewire port. I know I fried one of the two USB devices (flash drive) I plugged had plugged in before I realized my error. How would I know if I've damaged the motherboard?
Elixer
10,371
762
Eh? How the heck did that even fit ?
I guess you can check by plugging in another USB device, and see if it works.
CZroe
24,195
857
He obviously plugged the case's front-mounted ports into the wrong header.
OP: Correct the wiring and then try a Firewire device? MiniDV cam, external HDD, other Firewire PC, older iPod, really old PS2 model (like the 90001 series w/Sony iLink), etc.
Johnny Nuge
36
Already corrected the wiring. Front USB and Firwire ports seem to work fine. I have had my USB keyboard and mouse stop working a couple times while plugged into the back USB ports though.
CZroe
24,195
857
I think you're good to go then. My Logitech G-series equipment acts iffy like that* but I have an every-day mouse and keyboard plugged in as well.
*Probably due to complexity: high performance w/integrated hubs, displays, chargers, etc
Johnny Nuge
36
I've run some more tests, swapping another flash drive between the front and back USB ports. Data transfer speeds have been consistent. However, I did have a data transfer freeze during a test which also knocked out my keyboard and mouse. And every time those go out, I can't simply plug them into another USB port. I have to do a hard reset in order for them to function again.
Elixer
10,371
762
I meant that the cable should have been keyed to not allow this, I know the ones I have in my case are all keyed .
CZroe
24,195
857
Firewire and USB are keyed the same. Crazy designer, obviously.
There was a different layout used simultaneously in the early days of front USB. Some cases have each pin loose so that it can be connected to both standards.
